The washer takes water and starts working then it pumps the water out and all the lights flash red. can anyone help?
SOURCE: Kenmore Model 44052
Also remove the hose at the back of the washer. There is a restriction about 4 inches inside the hose that traps hairs and everything bigger than a toothpick.
SOURCE: red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
SOURCE: NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
