Getting no spark so I am thinking crank sensor is bad. Changed module with one that is good and still no spark
1998 Buick Lesabre 3.8L SFI OHV 6cyl
The dual Crankshaft Position (CKP) sensor is mounted to the front of the
engine, attached to an aluminum bracket mounted to the left side of the
engine at the timing chain cover. A 4-wire connector plugs into the
sensor, connecting it to the ignition control module.
Fig. 1: The Crankshaft Position (CKP) sensor is mounted to the front left side of the timing chain cover
REMOVAL & INSTALLATION
Fig. : If so equipped, remove the crankshaft position sensor shield
To install:
Hope this helps; also keep in mind that your
feedback is important and I`ll appreciate your time and consideration if
you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: Car won't start? 1992 Buick LaSabre
three core plug hahahah it has 3 coils crank sensor is located at the crank pulley it sits inside and creates a magnetic field and produces a low ac voltage 5 ac volts or less module then converts it to a squar wave to fire injectors and coils
SOURCE: 1990 buick lasabre with a
1. Monitor the 5v reference, Gray wire to the Throttle Position Sensor
(TPS) with a Digital Volt Ohm Meter (DVOM) set to the MIN/MAX setting.
2. Monitor the TPS signal circuit, Blue wire with a DVOM. Voltage
should range smoothly from approximately 0.44 to 5.0 volts as the
throttle is opened.
3. Tap test the Electronic Control Module (ECM) and see if the codes come back or if the engine reacts.
possible causes wiring or Powertrain Control Module (PCM)
SOURCE: 1989 buick century 3.3 V6 has no spark. Changed
the crankshaft sensor has to be adjusted or is will hit and break
