annie Posted on Jan 13, 2012
How do i find answers for jan 1st mail on sunday crosswords please?
Couldnt get last weeks mail on sunday paper (8/1 /12.) to obtain 1/1/12 solutions
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
437
Points
9
Call the newspaper that it appears in and they usually have copies of that. Or, you may also go to your local library and look them up on micro fish. Which your local librarian can help you with.
Enjoy!!!
Testimonial: "sorry ive taken so long to reply! thanks for the info.Ann"
Did not receive Sunday paper
Are you looking for the Sunday paper from our Church? Try this URL The first hymn we sung was Nearer my God to thee, it is also the last song played on the Titanic before it sunk.
Weekly Bulletin
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
1helpful
Date & time.
To reset system time you must be at the attendant station and with the handset cradled:
Dial: #06 4321 1 # (4321 is the default password)
Then:#55 YY, MM, DD, W, HH, MM, # time will be saved and phone will go back to normal operation.
Naming convention:
YY - Last two digits of the year
MM - Month (1-12)
DD - Day of month (1-31)
W - Day of Week (monday = 1.... sunday = 7)
HH - Hour (24hr format)
MM - Minutes (00-59)
ex: To set the time For Monday, Jan. 5, 2009 at 8:31pm I would enter: 09 01 05 1 20 31 #
Good Luck,
BB
4helpful
2answers
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
k24674
ADMIN Andrew
ADMIN Andrew
