Picture diagram of 350 vortec engine
SOURCE: 96 Chevy Z71 with vortec 350, Code 1406.
Yep that is what the code is for. Make sure the passage is clean after you pull it off.
SOURCE: engine swap 5.0 vortec to 350 non computer controled
5.0 heads will not work, most likely not the intake either.
SOURCE: Torque Specs for Head Bolts on 1997 GMC Sierra V8 5.0 Vortec?
.0L Torque Specs Belhousing to engine bolts 28-38 ft/lbs Camshaft sprocket bolt 40-45 ft/lbs Camshaft thrust plate to engine block bolts 108-144 in/lbs Crankshaft pulley to vibration damper bolts 35-50 ft/lbs Cylinder head bolts -1979-1992 --Step 1 55-65 ft/lbs --Step 2 65-72 ft/lbs -1993-up --Step 1 25-35 ft/lbs --Step 2 45-55 ft/lbs --Step 3 75-85 ft/lbs Differential shaft lock bolt 15-30 ft/lbs Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs Exhaust manifold bolts 26-32 ft/lbs Flywheel mounting bolts 75-85 ft/lbs Front engine mount nuts 72-98 ft/lbs Intake manifold to head bolts --Step 1 96 in/lbs --Step 2 16ft/lbs --Step 3 23-25 ft/lbs Intake manifold (upper intake to lower) 12-18 ft/lbs Oil filter insert to engine block adapter bolt 20-30 ft/lbs Oil pan mounting bolts -1979 --Step 1 (Large bolts) 11-13 ft/lbs --Step 1 (Short bolts) 7-9 ft/lbs --Step 2 (Large Bolts) 15-17 ft/lbs --Step 2 (Short Bolts) 10-12 ft/lbs -1980 to 1987 9-11 ft/lbs -1988 to 1993 6-9 ft/lbs -1994-up 110-144 in/lbs Oil pickup tube to main bearing cap nut 22-32 ft/lbs Oil pickup tube to oil pump bolts -1979 to 1987 10-15 ft/lbs -1988-up 12-18 ft/lbs Oil pump mounting bolts 22-32 ft/lbs Pinion bearing preload 8-14 in/lbs Pressure plate to flywheel bolts 12-24 ft/lbs Rocker arm fulcrm bolts 18-25 ft/lbs Spark plugs 7-14 ft/lbs Timing chain cover bolts 12-18 ft/lbs Vibration damper to crackshaft bolt 110-130 ft/lbs Wheel lug nuts 85-105 ft/lbs
