Washing Machines Logo
Posted on Oct 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer will not drain water or go into rinse and spin cycle
Model number for above washer is LSC8245AWO. The machine goes through the wash cycle and stops. It fills with water, washes and agitates the clothes. The wash water will not drain. The rinse and spin cycles do not work. I tried changing the timer with what I think is a new timer. The lid switch is broken.
I own the Do It Yourself repair manual for the washer, part number LIT4313896 REV. D. At page 35 problem 9 Water does not drain from washer: drain hose is not kinked, not too much suds, drain height is ok, no plugged drain hose, UNSURE ABOUT THE PUMP, lid switch broken, found no loose terminal or broken wire in wire harness.
HELP!
  • 1 more comment
  • pokney Oct 06, 2008
    This machine is a Whirlpool automatic washer direct drive model number LSC8245AWO. I tried the new time but the this did not solve the problem. However, the new timer may not have been a new timer...I am not sure about it being a new timer. POKNEY
    It is a top load Whirlpool washer super size. POKNEY
  • pokney Oct 15, 2008
    Mastermind 10 thks for the suggestions...try them out this weekend 101808. pokney
Anonymous
Level 3:
President:
  • Master 1,952 Answers
  • Posted on Oct 06, 2008
Anonymous
Master
Level 3:
President:
Answers
1952
Questions
0
Helped
698294
Points
5792
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
  • Anonymous Oct 06, 2008
    no magic to it, but double check your wire harness and make sure it is
    plugged in all the way. it is sometimes easier to plug the harness in
    before mounting the timer to the control panel.
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563566
Points
4850
Have you replaced the broken lid switch or not?
Anonymous
Level 2:
Scholar:
  • Expert 116 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
116
Questions
0
Helped
62357
Points
228
  • 8 more comments
    Washer wont run or spin...check the lid switch and lid switch wires first, Picture. Make sure the lid switch "clicks" and you should test it with a ohm meter. The timer is suppose to allow a "pause" before the machine can switch into pump and spin. If the timer misses this pause, the washer may not spin = new timer time. For some "how to test" for a no spin problem, please see here. Burnt wire ( esp at the motor ) can stop the washer from running. The start capacitor can prevent the motor from running, the start capacitor can be beside the motor, or up in the consol area. How to ohm meter test a capacitor.
    Bad cord or house fuse, try a radio in the washer power outlet to make sure it is live.
    for the pictures as where to look just click this link
    http://www.applianceaid.com/images/lwawp...
    how to check if the timer is fitted corectly
    Timer wont advance... Locate the 2 small black wires going to the timer motor, check these with the washer running for 120 volts. Power there and the timer won't advance = a bad timer.
    if misses the cycles then check this
    Missing cycles or timer stalls in middle of cycle...often this is a timer contact problem, remove power, access the timer and remove metal or plastic cover. Look for blackened or burnt contacts. If the timer contacts are pitted black or burnt, replace the timer. If you have to "wiggle" the timer knob to make the washer work, this is another timer problem, new timer time. New picture of a timer with a burnt contact is here. If your timer is moving part way through the cycle and then is stopping in certain parts, this link here may help you out.
    for the picture of the burnt contact just click here to check
    http://www.applianceaid.com/newpics/burn...
    whirlpool lid switches ....are failing in a strange way. The switch can be ohmed and will check ok, switch will make a "click" noise if you push a screwdriver down the hole to activate it, the switch body is not cracked or broken....but the switch is BAD!!
    The internal workings of the switch has lost it's "value" and has weakened....means the switch must be pushed all the way down to activate it rather than being pushed about 1/2 down to activate the switch normally. When the washer lid is closed, the lid probe goes down through the hole but can no longer push far enough to activate the switch. I have changed about many of these in the last year for this problem.
    Related links:
    ~ Accessing the lid switch on a direct drive washer
    ~ How to by-pass a lid switch for testing the washer
    Sometimes something works it's way into the pump assembly, this will make a clicking or scraping noise. When the motor drive coupler starts to wear down, the washer may also become noisy. Loose tub nut and drive block will be noisy in the spin only. See how to take apart info.
    just click on this blue lines for brief description
    Whirlpool direct drive washer- useful parts breakdowns.
    One the base.....
    Two the clutch.....
    Three the tub.....
    Four the top.....
    Five the brake assembly.....
    Six the transmission/gearbox.....
    if still any doubt feel free to contact.
    keep us updated for further queries.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
3helpful
2answers
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
33helpful
2answers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Top Washing Machines Experts
john h
