The power turns on, and the cd player plays however it wont let me skip tracks or higher or lower down volume, buttons are not operating probaly, cant turn on fm radio either.
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
SOURCE: Frozen buttons
Hi I am Vortash your radio I take it has a removeable security face , is it the type that folds down on a slide that allows you to put the cd in behind or do you place the cd through a slot in the faciure .. if it is the afformentioned then check the connecting ribbon is not damaged and cracked stopping the opperations .. if it is the latter check that the pins on the rear of the facia are clean and undamaged .. failing that there is nothing that you can do other than try a new facia or return it to the manufactures .. If you are In the Uk and your unit is under six years old then you have rights under the consumer act to get it repaired or replaced by the shop you purchased it from even if the guarantee has expired . All goods in the uk are coverd by this act so dont let the shop tell you any diffrent .. if they dont play ball report them to trading standards and they will take up your case in law . check out www.bbc.co.uk/oneshow and it is explained on there . If in the USA check out your consumer rights with the department of consumer trading .. hope this helps regards Vortash
SOURCE: sony xplod am/fm cd model cdx-m610 will play cds
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
SOURCE: sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
SOURCE: How do ya work this thing?
I had the same problem. I would just take the face plate off and put it back on, shift it around a little and after a couple DAYS of doing this it would start working again. It did this to me about once a month. Also to eject, slide the eject bar down so its covering the screen, then slide it down til it clicks, wait until the CD comes out before you slide the bar back up.
Once your player has started doing this volume this I suggest getting a new one altogether because it will drive you crazy.
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold (SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press < or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
