SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
SOURCE: WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
SOURCE: washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
