SOURCE: problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
SOURCE: Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
SOURCE: SONY DSC-W300 macro will not turn on
Looks camera requires RESET (Initialize) by following procedure.. Press HOME >> Settings >> Main Settings 1 >> Initialize >> OK and and enable Macro.
SOURCE: how can i use the macro in my sony dsc-w120
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
SOURCE: i can't use macro on my sony cybershot digicam
