SOURCE: Toro leaf blower has spark but will not start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You
will need to disassemble the carburetor and spray
with carb.cleaner. Make sure the small screen is free of debris.
(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),
to clean the small portals in carb. These portals can
become blocked. Reassemble and start.
Just let me know if you need further assistance.
Jim
SOURCE: How to convert blower to vac. Toro 850 super
Remove the air inlet guard on the bottom by pressing the release and pulling down on the guard. It will tilt off. Remove the blower pipe from the front of the machine by pressing the tab and wiggling it off (It is usually a tighter fit than the air guard). Install the vacuum pipe on the air inlet, where the guard was removed. Install the bag where the air blower pipe was removed.
Best regards, --W/D--
