We have a Whirlpool front load washing machine Mod GHW9100LW1.
The problem started while washing loads on white, about 1/4 way through wash machine started beeping with code HF flashing. I checked for blockadge and connection. A few times the door opened itself while machine was full of water. Other times I could pause and cancel and switch to drain and spin to get water out. Other cycles had similar problems.
Any help or should I call in a repairman?
Thanks,
Jody
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
I have the same problem. Error message HF, fills with water, starts the wash cycle and then stops.
Model# GHW9100LWS in service date 6/2004
all the water is not draining out of the washing machine
washer gives e 25 when time to spin washer tub
