Texas Instruments TI-83 Plus Calculator Logo
Posted on Sep 19, 2008
First time used in months
I have not used my TI-83 plus for a very long time. I put fresh batteries into the calculator and all I can see is random pixels. I cannot even get the functions to work. Is my calculator dead from sitting on the shelf with no batteries for too long?
  • rockstar944 Sep 26, 2008
    I'm having the same problem.... my calculator has sat for about 4 years, at least. Now i need to use it for a class that i have in college. I turn it on, but the pixels are all messed up. it can do basic calculations, but if i type in a lot or numbers and functions, it does not show up like it's supposed to. Is there anything i can do, or is my calculator just done for? I tried new batteries, and it appear that it had solved it....but 5 seconds later, after typing in a lot of numbers, it's back to its old ways....
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Sep 19, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
6306
Points
26
Check the batteries polarity.
Perhaps it needs a "reset", some calcs do have a "button" therefor, some do if you press the start button for some seconds.
Try to leave the calc overnight without any batt. inside.
1helpful
TI-83 Plus Calculator, battery corrosion, wont stay on and when it stays on for awhile, it turns back off. ON the Calculator it show that the Ram is cleared. want to know what that means and how long...
When it says that RAM Cleared every time you turn it ON, that means the backup battery is depleted and needs to be replaced with a fresh one. The calculator has an automatic power down to save energy.
There's something wrong with my TI-83. When I'm typing up an equation it will randomly shut off. And when it's on it will have shown that the RAM was cleared. Now it sometimes takes like 5 presses of the...
Have you tried changing the batteries? I'd try that first thing. From your description, the problem sounds like you have low batteries. The RAM shouldn't clear itself when you turn the calculator on unless you tried to turn it on when the calculator didn't have any juice. The TI-83 has four AAA batteries and one CR1616 battery it uses for memory backup. The CR1616 isn't enough to power the calculator, just enough to keep your calculator from losing its RAM contents while the primary batteries are out. If you try to power the calculator on without primary batteries, the backup fails. However, the TI-8x line is usually pretty good about warning you when the batteries are low by displaying a big warning message when you turn it on about the batteries being low and a recommended change of batteries. It might not, though, so you really can't be sure until you try a fresh set of batteries. Good luck!
I haven't used the calculator in a long time(TI 83 plus) and I put in a new set of batteries. The old ones that were in left some battery acid, but not much. The calculator doesn't want to turn on. It's a...
hi adamsukienni,
Clean the battery damage up real good. Gently scrape to terminals of corrosion. Back in my day we use to put a little bit of coke cola to clean car battery posts to get a good connection. If you could put a little bit of coke on a Q-tip without getting any inside the calculator that would be good. Just let it soak in for about 30 minutes. And gently scrape the bad areas again clean of the corrosion. You have to clean it up to metal so, that when the battery is in it will be metal to metal connection.
If you can download new OS with another Ti83 Plus or, don't want to install the new OS goto Procedure 1.
Be ready to install the new ti 83 OS v.1.19. So, setup your computer with Ti Connect software and, have the new OS v.1.19 download ready and, in "My Documents \ My TI Data \ Downloads." If you need additional instructions on how to connect the computer to the calculator you can read my instructions at another posting I did. You can go to that posting by clicking, "Connection Instructions," under this paragraph. Just remember the OS was for a Ti 84 Plus and, your's is a Ti 83 Plus so, don't download the OS from the other posting. I'll give you a link below this paragraph to download the correct Ti 83 Plus OS v1.19 for your calculator here at your posting. Just follow the other posting to where I say, "You can also go back and, download the Ti 84 Plus guidebook too, if needed." After that statement the computer and, calculator get connected with the cable and, your not ready for that process, yet! When you come back to this posting and you have downloaded the new OS to the proper folder goto Procedure 1.
Additional computer to calculator connection instructions click, "Connection Instructions."
Ti 83 Plus OS v.1.19 download click, "Ti 83 Plus OS v.1.19". Save this download to "My Documents \ My TI Data \ Downloads".
Procedure 1.
Take all the batteries out for 10 minutes, including the very small one that you have to use a small philips screw driver to get it out. Watch out for the spring under the small battery, it might pop out. Replace all the batteries after 10 minutes with new ones, including buying a new small battery. The small one might cost about $5. I know it is expensive but, this might work.
A battery reset procedure should bring your Ti 83 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
If your Ti 83 Plus turns on when you put the batteries back in you do not have to re-install the OS. I just think it is better since, your OS might be corrupt.
The process below should reset your calculator.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done. Once again, if your calculator turns on after this procedure you do not have to re-install the new OS. You can quit these procedures now with a perfectly good calculator.
Please be prepared to re-install the calculator's OS, if you run through this process.
2). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". Connect to other Ti 83 Plus and, install OS from that calculator. Or, follow the instructions, I gave at the other posting "Connection Instructions" to reinstall the calculator operating system and, connect the computer and, calculator. You can start where, I say, "Link your computer and, Ti 84 Plus (Your's is a Ti 83 Plus) with the proper cable (USB or Black Link). Upon completion your Ti 83 Plus will be ready to use and, the new OS installed.
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
I put new battery in my ti-83 plus, but it still wont turn on
Having received no response in over five months, I assume the suggested contrast adjustment solved the problem.
Calculator not turn on for my TI 83 plus silver edition, i even put on new battery
Having received no response in over a month, I assume this is no longer a problem.
BLACK LINE WHEN TRY TO TURN ON TI-83 PLUS
it seems it have an internal problem of contact and you must get it repair, or consider buy a new one that model is a little old.
2helpful
TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Ti-83 plus silver edition for overhead projector hook-up
You can try to put fresh Back-Up batteries into the calculator. If not, you can always call the customer support at Texas Instruments to see if you can get a replacement part for your calculator. This may resolve the problem you are currently having. Hope this helps.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
