Hi and welcome to FixYa, I am Kelly,
Since I don't have a model number to work with I am going to assume this is a generator with brushes. (I need your model number!)
Having said that... TRY THIS:
1. Plug in an electric drill to the output power plug and turn on the output power switch with the generator running.
2. Squeese the drill trigger switch and rotate the drill chuck as fast as you can. This will flash the field of the generator and often output power starts right away. NOTE: When power starts it will try and twist the drill chuck out of your hand. Just let go of the trigger and the drill chuck.
If you have an inverter type power head the steps are different for flashing the field. The easiest way is to do a male to male power cord from utility supply power connection and turn on the output power switch to re-establish a field in the PMG of the rotor.
There are other steps but without a model number this is what I am sending off at the moment. Respond with a model number if the steps above do not work and I will help you.
Thanks for choosing FixYa,
Kelly
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
