AEG Lavamat 72640 Front Load Washer Logo
Posted on Aug 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Lavamat L14510 washing machine. The power tripped today and when I put it back on the washing machine was giving an error E60. There was a blockage in the front filter, so I entered the water and cleaned the filter, but I have no idea how to clear the E60 code and reset the machine. I have tried turning off at the mains but this does not work.
  • slackalice Aug 15, 2011
    Thank you for this advice. However, I cannot be certain that it was the washing machine that cause the 'trip' because the kettle was also on at the same time. Do you know how to reset the machine so I can clear the "E60" error code. I will then try and turn the machine back on, if it trips the RCD, I will call an engineer. I know that with an AEG it is possible to complete a reset with a series of buttons, but I don't know the order.
abdo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 28, 2017
abdo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
169
Points
What the Meanning the E 10 eror for the aeg lavamant 66815??
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Aug 14, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1026464
Points
20216
As you say that the filter WAS blocked but you do not say if you were able to check the drain motor/pump itself, I would advise checking the operation of that first by following the notes through to those in bold italics ;-0)
(This is pre-typed as I cannot type that fast!)
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor:-
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Anonymous
Level 3:
  • Master 10,515 Answers
Anonymous
Master
Level 3:
Answers
10515
Questions
Helped
2936029
Points
31530
E60 error code is a heating problem.
What you need to do is take the back cover off and from there you will see the heater in the back of the drum at the bottom.
Make sure the wires are still in place on the heater. If they are then you will need a multimeter and meter the heater out. It should read about 28 ohms. If faulty then it will need to be replaced.
If the heater and the wiring check out OK then its probably the control board that's the problem here i am afraid.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
AEG washingmachine LAVAMAT 74825 after years of brilliant service its showing errorcode E60. Whatcan I do to rectify or if I need to call a service engineer what is the telephone number please. Thanks
This sounds like it is the heating element in the machine. Check to make sure the heating element is getting power. If it is then replace the element.
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
My aeg lavamat 41070 washing machine doesn`t work at high temperature ( more then 50 degrees) . At low temps it is working OK/
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Dado
2answers
Stirling xqg65-908e manual
4helpful
2answers
My AEG Lavamat 66600 Washing Machine is showing E60 Message how can I remove it to get the machine working again. Thank you
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60.
Check the door switch,drain pump and inlet flow.
Error code E320 appears and the machine has failed with this code
Go to the very bottom right of the washing machine, open up the flap; there is a round filter. Open up the nozzle and put a towl down underneath- once the water has stopped coming out, twist the whole filter until it lifts out. Clean this (there may be money and fluff in here) with water. Put it back in. Put the washing machine on a high temperature wash without anything in. This will give it a good clean, and get out any residue from products used. It should work okay after this.
1helpful
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
2helpful
Error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
1helpful
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
