Maytag Centennial MTW5800TW Top Load Washer Logo
Posted on Aug 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Aug 13, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10838716
Points
101584
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Testimonial: "I actually figured out the problem......one of the kids overloaded the washer and this is what caused the water not to spin out completely. Thanks!"
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Clothes were still very wet when cycle completed
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
10yr whirlpool toploader wash machine no spin/agitat. but works?
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Spin cycle not working properly, clothes still wet!!!!
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
1helpful
Clothes are still water logged after cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
From Repairclinic
Will not high spin
The brake assembly is failing ,try this if you can,loosen the 3 transmission bolts about a quarter inch and try it in spin.If it picks up speed than you are going to be due to have the break assembly replaced.High cost repair. :(
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
