20 Most Recent
Lionel Cw 80 Transformer Questions & Answers
CW 80 -Direction button doesn't work
Recent Lionel transformers are notorious for their issues. Put an old fashioned reverse switch into the circuit, an old Lionel 88 will do the wire to terminal 1 of the lockon or the wire tothe center rail needs to be cut and attached to the 2 terminals of the 88 reverse switch. Note this is ancient technology from the 30s to 50s
Lionel Trainmaster KW 190 Watt Transformer
The Lionel postwar 190watt transformer is an excellent power supply for trains. If one or more of the binding posts are loose ("U,A,B,C,D" Terminals") you will need to replace the binding post, use a T-159 replacement Binding Post. The original posts are soldered and crimped on.
The T-159 replacement binding post is bolted on. UNPLUG THE TRANSFORMER Carefully pull/pry up the handles and remove them remove the 4 Philips screws on the top, lift off the case top, the binding posts stay with the body of the KW.
Remove the loose bindings post one at a time as needed. Be sure to get any wire reattached. Reverse the procedure to reassemble.
My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
How to remove the red handle and how to get to the fuses
You can't. These transformers aren't user serviceable. You can thank the Federal Government for that. If you can find the special tool to remove the case, you'll be able to open the transformer. For service, contact Lionel customer service or take the transformer to a Lionel Service Center.
My transformer did not work
The internal fuse is probably blown. Contact Lionel at Lionel.com for instructions on how to get a replacement.
My lionel rw transformer won't
Yes. Find a Lionel repair shop or bring it to a local hobby store that does model train repairs. You can contact Lionel for a list of repair shops.
Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
