20 Most Recent 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Questions & Answers
3answers
WEAK SPARK AT PLUGS
That truck should have no points. It should have electronic ignition. Sounds like bad wires or bad coil(s).
2/17/2024 9:55:50 PM • 1995-1997 Chevy... • Answered on Feb 17, 2024
Gear indicator
When you move the gear selector and the shift indicator does not move, there is a problem with the indicator. Misalignment could be a reason that can be solved with an adjustment by a trained mechanic or there may be a more serious problem.....For more info-https://www.usedengines.us/blog.php
3/15/2023 6:56:06 AM • 1995-1997 Chevy... • Answered on Mar 15, 2023
2answers
I need wiring diagram for ignition switch for 1997
red and red/white is 12 volts constant
pink is ignition
white is ignition 2
orange is heat/ac
brown is accessory
8/27/2022 4:40:49 PM • 1995-1997 Chevy... • Answered on Aug 27, 2022
1997 chevy truck 1500 neutral safety switch doesn't work
If you follow the steering column down the sw. is a half moon shaped sw inside attached to the column. Remove the wiring clip and the two screws and put on the new sw. be sure the truck is in park or set the new sw. to the position it is in now. Better to have it in park.
7/7/2020 4:50:40 PM • 1995-1997 Chevy... • Answered on Jul 07, 2020
How do I remove the dash cup holder on a 1995 chevy pick up
under the cup holder there is a part that looks like a flat blade screwdriver would fit in , get a screwdriver and twist counter clockwise and remove this part and the cupholder should slide out.
12/17/2019 11:23:31 AM • 1995-1997 Chevy... • Answered on Dec 17, 2019
What size bolts do I use for the undercarriage?
you can get guide from many sites.. i know few error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered within seconds u can get the access and it's totally illustrative complete
1/28/2019 10:46:29 AM • 1995-1997 Chevy... • Answered on Jan 28, 2019
I have a 1997 chevy c 1500 it starts and dies in 7 seconds what could the problem be
You may have a spark problem. Hook up a remote spark tester and locate it where you can watch it . Watch to see if there is a lack of spark when the engine dies. Also hook up a remote fuel pressure tester and see what your fuel pressure is when the engine dies. If you lose spare I would look at the module in the distributor as the problem. If it fuel, it could be a weak pump or a restricted fuel line. Also , find someone with a scanner and have him read the codes. It could be that simple.
12/7/2018 5:49:24 PM • 1995-1997 Chevy... • Answered on Dec 07, 2018
1997 Chevy C1500 keeps blowing the ECM-B fuse
Check for a shorted wire that goes to the throttle body injectors. They get caught under the air cleaner and short out.
12/7/2018 1:18:27 AM • 1995-1997 Chevy... • Answered on Dec 07, 2018
1995 chevy 350 egr valve problem
Thank you for this information. I have run into this problem before.
11/25/2018 2:45:52 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
95 z71 new fuel pump no fuel to injectors an no
The injectors must receive a signal from the ECM to fire. What is your fuel pressure. 60-65? Check the injectors wires to make sure they get current to fire. Possible blown ignition fuse. Red 10 amp fuse in fuse panel.
11/25/2018 2:44:33 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
1997 chevy 1500 cheyenne Manual Transmission
Check the fluid in the clutch master cylinder. It may be low. You may need to bled the system or replace the slave cylinder. If both of these are on, you may have a clutch problem.
11/25/2018 2:41:20 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
95 Chevy Silverado Z71 fuel injection problem
You could have a bad engine coolant sensor giving the ECM a bad temp reading. It is located in the front part of the manifold.
11/25/2018 2:39:22 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
Repair inside door handle and latch on 1995 Chevrolet Truck 1500
Pull the door panel off. Disconnect the linkages from the old assembly. Remove the rivet hood the assembly to the door. Slide the assembly forward to remove. Put new assembly in and reverse the order to reinstall.
11/25/2018 2:37:44 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
1995 silverado fuel injector problem?
Check for a bad ignition fuse in the fuse block. Should be a red 10 amp. If bad, check all of the injector wires to see if one has been grounded.
11/25/2018 2:35:10 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
Why does my 1997 chevrolet
It could have bad wires, wires that were crossed during a tune-up, low fuel pressure, bad intake valve, slow timing, too lean of fuel/air mixture,worn cam shaft bad injectors
11/25/2018 2:30:57 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
Knock sensor 05 chevy truck
On the lower part of the engine block
11/25/2018 2:28:07 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
1995 V8 350 CI CHEVY 1500 WONT STAY RUNNING
Possible a very bad vacuum leak. Also could be bad fuel. there again maybe that your plugs are worn of your fuel filter is dirty. Could also be that your ect sensor is bad. A few of the things for you to look at.
11/25/2018 2:22:04 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
Eng-i fuse in 1996 chevy silverado keep blowing
Check your power outlet ( cigarette lighter) to see if shorted.
11/25/2018 2:18:05 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
Installed new fuel injectors in a 1997 5.7 chevy K1500 4WD. Won't start
How much fuel pressure do you have. Should be 60-65 psi.
11/25/2018 2:17:02 AM • 1995-1997 Chevy... • Answered on Nov 25, 2018
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
510 questions posted
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Vehicle Parts & Accessories
Most Popular Question
chevy 1995 silverado hard start
  • Vehicle Parts & Accessories
