20 Most Recent Mantis 2-Cycle Tiller Questions & Answers
you have hole in bulb or the fuel line check both or replace
Mantis 2-Cycle... | Answered on Sep 18, 2018
Try by tightening both setting screws (not too tight as this will damage them) ...just enough to the home position...then backing off 1-1/2 turns on each. Try to start, if does not start, then then back off another 1/4 turn, continue till you can start then once started regulate adjust screws slowly to find a smooth idle.
Mantis 2-Cycle... | Answered on Jan 09, 2018
Turn the carb mixture screw all the way in until it bottoms out and count the turns as you do that, then turn it out the same number of turns plus 1/2 more and see how it idles, if it runs poorly try turning it in and out slightly for best idle.
Mantis 2-Cycle... | Answered on Oct 17, 2016
Replace spark plug
Pour out old fuel and replace with 2 cycle fuel. Plan gas will not work!
Mantis 2-Cycle... | Answered on Jun 29, 2016
For what? I need to know what size engine. or equipment you are working on to be able to help you. send more information.
Mantis 2-Cycle... | Answered on May 08, 2016
check what they call air gap between the coil and flywheel .010-.012 gap
also be sure your flywheel is in time.
you will actually have to remove it to do this and check for the sheared key or be sure the key way aligns with the crankshaft keyway on the flywheel
Mantis 2-Cycle... | Answered on Dec 04, 2015
Mantis Deluxe Tiller operator manual
This maybe what your looking for
Mantis 2-Cycle... | Answered on Jun 12, 2015
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
bad clutch .
Try www.mantis.com. You should be able to find the manual for download or request one from Mantis.
did you put oil in gas .
Mantis 2-Cycle... | Answered on May 11, 2015
check the exhaust screen if it gets plugged with burnt(soot) /unburnt oil it will not let engine start
Mantis 2-Cycle... | Answered on Apr 24, 2015
the diaphragm goes in with the large circle towards the needle
the fuel inlet side goes in with the clear sheet against the body and the rubber one on top.
Mantis 2-Cycle... | Answered on Mar 30, 2015
if the primer bulb cannot pick up fuel and the fuel lines are good then you have a bad primer plate and you need a new carb
-Adjust it.
Good luck
mai
Mantis 2-Cycle... | Answered on Sep 06, 2014
Mantis 2-Cycle Tiller Logo
492 questions posted
Top Mantis Garden Experts
ray gallant
ray gallant
mpservices
roeb
Are you a Mantis Garden Expert? Answer questions, earn points and help others
View Most Popular
Mantis Garden
  • Mantis Garden
Most Popular Question
carburetor settings mantis tiller
  • Garden
