20 Most Recent
Kodak EasyShare M863 Digital Camera Questions & Answers
Kodak md863 turns off right away after turning on,
Your fix could be as simple as cleaning the camera's battery contacts,
or it could be something more serious and expensive. Before you pay
for expensive repairs that you may or may not need, check the Kodak
Help Center by clicking on the link below. It uses a simple Q&A
format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Kodak M863 camera built-in flash stopped working.
make sure the setting is on auto or something . check the knob at the top .
if your internal memory is full, then you need to either put the pics on the computer or delete them . get a memory card so you have more room .
try taking out the battery for a little while or charging it .
if your niece deleted it all then it's gone , i'm sorry .
Software for m863
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
How do i turn off the date/time on my kodak
Press the MENU button. Use left/right-arrow to select the Capture tab (the camera icon without the "+" sign). Use up/down-arrow to select "Date Stamp" and press the OK button. Select "Off" and press OK.
I need to know how to get the pictures from my
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
