20 Most Recent Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Questions & Answers
0answers
2answers
I am needing a repair kit for gas tank on the
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
4/21/2016 5:57:51 PM • Poulan... • Answered on Apr 21, 2016
Pour bar oil in and it comes out the other side on the ground - why??
I'm sure this should be in the chainsaw category, not (blowers) Check the tank housing where the two crank halves meet, check the oil pump and the gromit between the tank and the pump are in place.
4/18/2016 7:50:25 PM • Poulan... • Answered on Apr 18, 2016
3answers
FL 1500 blower won't start
Home depot sells new lines and bulb
2/26/2015 11:38:36 AM • Poulan... • Answered on Feb 26, 2015
Poulan pro blower will not start
turn the carb screw all the way in and back out 1 1/4 turns.
1/25/2015 8:36:23 AM • Poulan... • Answered on Jan 25, 2015
Weed eater FL20 very hard to pull rope to start
Is it possible the engine is seizing?
1/25/2015 8:07:23 AM • Poulan... • Answered on Jan 25, 2015
How do i replace the starter assembly in a small gas engine?
Some starters are buried in the cases and some are on the outside. Yours.....unfortunately...is buried in the case. The cost of parts and the time involved tell me your best option is get a new one! Sorry.
11/26/2014 10:07:12 PM • Poulan... • Answered on Nov 26, 2014
Are you stupid? I wrote that WHEN I PULL CORD I AM NOT GETTING ANY SPARK. YOUR ANSWER,TWICE is to REATTACH PULL CORD.
wow! That is pretty funny. Ok....now lets check this out again. Take off the spark plug lead and then get a plug socket and remove the plug. Now reconnect the plug to the plug lead and set it on top the engine to ground it and pull the cord. If it has spark you should be able to see it. And leave the cord alone! ha ha! Also, look at the plug when you pull it and see if it is wet with fuel or water. A lot of these small engines have gotten fussy about fuel and one bad tank will ruin your season!
11/26/2014 9:36:04 PM • Poulan... • Answered on Nov 26, 2014
I am not getting a spark
No spark can be a bad switch *(need to go in and unplug it from the ignition module and retest) or your ignition module has given up the ghost. Get a t-handle set and go online and look up the parts. A module might cost more than a new unit....I think we both know what that means! Be safe and good luck!
11/26/2014 9:32:42 PM • Poulan... • Answered on Nov 26, 2014
[email protected]
what's it doing or not doing I don't under stand what you mean low emission, does that meen wont rev up?
9/3/2014 5:48:34 AM • Poulan... • Answered on Sep 03, 2014
YOU have told me to reattach the pull cord 3 different times.
Laying the spark plug against the cylinder head is not an ideal way to check for spark. The best way is with a tool designed specifically to check for spark available at most auto parts stores. Remove the spark plug from the engine. One end of the tool plugs into the plug wire the other end is a clamp and gets clipped to cooling fins or another good ground on the motor. Pull the cord and you will be able to see and hear the spark.
7/28/2014 12:40:45 AM • Poulan... • Answered on Jul 28, 2014
2answers
I have a Pulan Pro 25 gas air blower. The rope
hi there the wire sounds like it goes to the chasis of the machine (earth) but it could also go onto the coil but if it comes off the kill switch then it will go onto the chasis earth (metal casing) hope this helps ben
5/12/2014 4:01:46 AM • Poulan... • Answered on May 12, 2014
0answers
Rewind cord spring
Be the first to answer 12/14/2013 3:16:01 AM • Poulan... • Posted on Dec 14, 2013Be the first to answer
I can't remove the impeller. I have removed the nut , lock washer, and flat washer, but the impeller won't budge. It looks like it should just slide off. Is it threaded? If so, how do I hol
look there might be a set screw look for a hole on the impeller on the side ! and try sum wd40 spray ...good luck
12/11/2013 6:57:33 AM • Poulan... • Answered on Dec 11, 2013
3answers
Is the weedeater featherlite fl 1500 gas blower a
2 cycle engine takes a 40:1 gas mixture.
Good Day.
10/22/2012 6:28:24 PM • Poulan... • Answered on Oct 22, 2012
What size spark plug do i use for a feather lite 150mpg weed eater or blower
Go to a lawn shop and they should have the plug you need!
10/18/2012 8:38:45 PM • Poulan... • Answered on Oct 18, 2012
MY ROPE WONT GO BACK IN?? HOW DO I SOLVE THIS
well, either the screws that hold the plastic on (thats hooked up to the rope) are loose, or the spring in the recoil is wedged, missing, or dislodged. Might want to take off the recoil and check for any missing parts, wedged in or dislodged. if none of these is the case, try asking a person at your local hardware store, (home depot, westlake, strausser, harbor-freight, Lowe's)
8/21/2012 4:06:32 PM • Poulan... • Answered on Aug 21, 2012
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
150 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
fl 1500 blower start
  • Garden
