20 Most Recent
Craftsman 26 Hp 54" Deck Yard Tractor Questions & Answers
Deck Height Adjusting
you should have holes on the arms of the adjuster look for the most worn hole that is where the studs should go
I have a 2007, 6500
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Blades won't enGage motor dies
First unplug the plug wires, take key out of switch, then check to make sure that the blades will move by hand. there could be a dirt mound or rock jammed in there
Belt diagram
search for your model # (should be able to find it on label under seat). You should be able to find users manual on sears site. This will have belt diagram for both drive and deck belts.
