20 Most Recent
Sony Cyber-shot DSC-T70 Digital Camera Questions & Answers
My Sony DSC T70 shakes & vibrates
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process .
Vibration of camera
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
Need to download a manual
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Dslr a350 owner manual
You may download the manual and more from http://esupport.sony.com/US/p/model-home.pl?mdl=DSLRA350&template_id=1®ion_id=1&tab=manuals#/manualsTab
Software Sony HDR-TG1 Japanese version change to english
If the camera came from Japan, there will be no english in the camera. If the camera had English before, you could try to switch the language back, by using the manual and count lines in the menus, to "feel" what part of the menu you are. (Setup menu)
