20 Most Recent Kenwood KVT-512 Car DVD Player Questions & Answers
The kenwood in-dash (KVT-512) is
you have to wait a second or two after each letter before you enter the next letter.
6/11/2022 8:42:26 AM • Kenwood KVT-512... • Answered on Jun 11, 2022
Code set for a Kenwood KVT-512
Use KCAR for the code.
6/11/2022 8:39:39 AM • Kenwood KVT-512... • Answered on Jun 11, 2022
2answers
Ive got a kenwood kvt-512 n im tryin to hook an
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
12/1/2021 12:45:56 PM • Kenwood KVT-512... • Answered on Dec 01, 2021
3answers
I sent a Kenwood KVT-514 to my niece in Europe. I
no you must send her us dvds
10/16/2019 9:20:01 PM • Kenwood KVT-512... • Answered on Oct 16, 2019
Kenwood kvt-512 mecca error
Blue wire is your amplifier remote or power antena, if you ground it and turn the radio on you burn somethin hopefully j6st a fuse.. You did check the fuses, when in doubt the chassis of the radio is also your ground.
3/7/2018 12:51:53 PM • Kenwood KVT-512... • Answered on Mar 07, 2018
0answers
3answers
Need installation instructions
do you still ned the intructions on how to install your kenwood kvt-512??
9/10/2014 2:12:06 AM • Kenwood KVT-512... • Answered on Sep 10, 2014
Screen is white blank
try resetting it
9/9/2014 1:15:47 PM • Kenwood KVT-512... • Answered on Sep 09, 2014
Kenwood kvt512- IPOD hookup not working...wont work in usb either
kenwood.com/cs/ce/mm/firmware/2008/eng.html
this is the firmware update I used to get my Ipod to work on my kvt 512
8/4/2014 10:52:26 PM • Kenwood KVT-512... • Answered on Aug 04, 2014
3answers
I plug my ipod to the stereo but my stereo screen
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
8/4/2014 10:50:05 PM • Kenwood KVT-512... • Answered on Aug 04, 2014
2answers
Ipod says disconnected when plugged into my
i sometimes have the same problem it says do no disconnect when it should show the kenwood logo
try restoring your ipod from itunes
8/4/2014 10:47:05 PM • Kenwood KVT-512... • Answered on Aug 04, 2014
Brake Bypass Code
I just spliced the brake wire into my cigarette lighter positive wire to provide the voltage necessary to bypass the parking brake requirement for video. Worked like a charm. It takes almost no voltage to bypass it. Even just licking your fingers and holding the bare wire allows video to show.
7/17/2014 5:10:40 PM • Kenwood KVT-512... • Answered on Jul 17, 2014
Kenwood KVT-512 Car DVD Player Logo
176 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
como le hago para ponerle
  • Car Audio & Video
