20 Most Recent
Maytag NFW7200TW Front Load Washer Questions & Answers
Nd code and door locking
There could be another coin in the drain pump, jamming it.
With power disconnected..........Does the pump turn by hand in both directions?
Amana NFW7200TW just won't start.
i don't know what the guy did for you by playing with the knob but i just looked that washer up and you can't get hardly any parts for this machine,must be old,i wouldn't put any money into it because like i said you can't get the computer board or any parts anymore not even the knob lol
My amana front load washer wont spin and is
Hi
Thanks for using FixYa. From what I understand the error code ND means “No
Drain issue”. You’ll need to check for any restriction in pump assembly. It can
also be due to a restricted drain hose or loose wire at pump. If after cleaning
the drain hose the issue is not resolved then it means the pump has gone bad
and unfortunately needs to be replaced. Please do rate the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
No spin
Is there water in bowl? If So then check the drain pump for blockages or not running. The spin will not start if there is water in the bowl
