20 Most Recent
Danby Silhouette® DWC276BLS Wine Cooler Questions & Answers
Cooling - not
Have a heating/air conditioning person check the freon level to see if it needs to be refilled. Most modern day things that cool use freon gas to cool. It could be that it needs to be flushed and refilled, or perhaps you have a leak somewhere and all the freon is leaking out or has leaked out. Trust me one of my uncle's is a heating and cooling technician at a company called WinAir and he has fixed our home cooling systems many times. Those guys have tools, freon, and the right chemicals to see if you have a leak and need more freon.
4/6/2014 11:50:43 PM •
Danby...
Answered
on Apr 06, 2014
Danby silhouette dwc276bls e2 error solution
Hi There, The E2 error codes indicates there is an problem with one of the sensors.Please contact our customer service department for information on repair.1-800- 26- DanbyThanks!
7/19/2012 3:41:48 PM •
Danby...
Answered
on Jul 19, 2012
Cannot get Danby Silhouette 166
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
8/23/2011 12:19:16 AM •
Danby...
Answered
on Aug 23, 2011
Danby DAR044A6LDB Mini Fridge. Where are the condenser coils on it please?
The two lines entering/exiting the lower right of the attached photo (back view) should be the condenser as the lines on left side appear to be for evaporation. Looks like they buried the coils inside the right side panel and possibly the top. The coils may be bonded to panel metal and the metal is what radiates extracted heat.
11/8/2023 11:00:45 PM •
Danby...
Answered
on Nov 08, 2023
Danby Chest freezer leaking
No it is time for a new one. There is either a leak on the inner liner or the insulation between the inner layer and outer layer has broken down and is causing condensation.
9/13/2023 6:48:18 PM •
Danby...
Answered
on Sep 13, 2023
Danby DBC514BLS-1 beverage frig not cooling
If your Danby DBC514BLS-1 beverage fridge is not cooling and you have noticed frost on the back coil, it could be a sign of a problem with the fridge's defrost system. Here are some steps you can try to troubleshoot the issue:
- Check the fan to see if it is running. If the fan is not running, it may be a problem with the fan motor or the control board.
- Check the defrost timer and thermostat. The defrost timer controls the defrost cycle, and the thermostat monitors the temperature inside the fridge. If either of these components is faulty, it could cause the fridge to frost up.
- Check the wiring and connections. Make sure all the wires are securely connected and that there are no loose or frayed wires.
it is possible to replace the fan in your model of fridge, If you decide to attempt the repair yourself, you will need to purchase the correct replacement fan for your fridge and have the necessary tools to make the repair.
6/14/2023 7:12:01 AM •
Danby...
Answered
on Jun 14, 2023
