20 Most Recent
Activision Call of Duty 4: Modern Warfare for Xbox 360 Questions & Answers
How to deal with cheaters on call of duty modern
How to deal with cheaters on call of duty modern warfare 2 is to fill out a aovid player and smit a review on the player. But xbox live will look in to it but the seem take a lil bit.
GOOD LUCK
EnVy
I got hacked
you have to delete your online account.you can do this by going to account settings and then going to memory go to call of duty 4,modern warfare then click on your gamertag next to your gamer tag will be online progress do not press campaign progress unless you feel like doing your single player over.then press delete you will have to make a new account online but atleast you will be able to play.
Hi, I was level 37
This is very common now in Call of Duty 4 and you have to be careful in the future. There is people out there that hacked the game and are deranking players with a customized Xbox called a J-tag. There is nothing you can do but try to get your level back or joining a lobby that ranks you back up to your desired level. For future reference, whenever you encounter one of these lobbies and you get a kill that has a -exp, immediately dashboard, nothing will be saved and your stats will remain the same since before that game.
A little while ago my
This is a common problem it is most likely a scratch but you may want to try wiping the disc down with a piece of cloth, or it could just be some corrupted data on the disc so you may just need to buy a new one
My odern Warfare 2 is
if your disc is broken then it wont matter if it is saved to your hd because you still need the disc to play. hope this helps
I was playing a game and suddenly it went off and
Well first try blowing into the actuall disc drive if still dosnt work ask one of your friends if you can borrow the same game install it to the xbox that is if you have a hardrive then give tjhe game back and when you want to play the game put in your game make sure the setting automaticlly start disc if of and go to game library and go to the game and play it and it will work
Mw2 being read as a dvd
check if it scratch...
if it scratch which means you need to buy a new disc
remember it is not advise to move the xbox while the disc is still inside
