20 Most Recent
MTV Games Rock Band Bundle for Xbox 360 Questions & Answers
Bass pedal stopped working
Exchange the whole set for a new one at the store, if it's still in warranty. Some custom pedals don't work with every set.
Have rockband 2 and have
Make sure you are in the correct user profile. If you are not using the live account that you downloaded it from it wont work.
Cant get my r3 guitar to syncI tried all of the
Well first of all , in rock band all guitars should be able to sync. Restart the system and hit the sync button on your xbox 360 face plate. You will see a little hole on the front to the left of the power button and before the disc drive. Get a quetip and take off the cotton . Then you use the uncotton side to put in hole and press in for 3 seconds. Then you quickly hold down the x power button on the r3 guitar for about 5 seconds and they will both be flashing . when they stop they should be synced and ready to play . This will solve your problem!
When I press yellow fret, both yellow and blue
Sounds like you may need to buy a new one or replace the connections internally If you got it wet with something sticky(ewe) then when you press one it is making the other connection press too or the if the connection is not completely centered internally then one could be pressing on both. Or, maybe it has something to do with the wire connection where something is completing the circuit to make both get the signal. Goodluck and try not to rock out to hard or maybe try not to abuse it as it is only plastic.lol
Just got rockband for xbox 360 and the guitar will
I'm guessing you have a wireless guitar and you need to sync it to your xbox by pressing the white button next to your memory card slots on the xbox and the one on the guitar it is probably around the body of the guitar
Footpadle dosn't work anymore
Foot pedal, you mean? If you are still within warranty, then take it to the store, if you got an extended warranty, then give you a number at the store to call. If you have an extended warranty, call the number and request an adress label, and put it on a box and UPS/FedEx your foot pedal to them, if you don't have a warranty anymore, you're out of luck.
