20 Most Recent EA - Electronic Arts Rock Band Questions & Answers
2answers
My rock band game thinks my rock band 3 fender mustang pro-guitar is a microphone how do i change that ?
Have you tried reassigning the guitar to another controller port, one that's not linked to the microphone? Or are you using a different dongle with the guitar than what came with it?
12/15/2021 4:19:10 PM • EA - Electronic... • Answered on Dec 15, 2021
4answers
My ps2 wont read the disk. says there is no data. help
it's your laser with something like dust keeping it from reading the discs. Just get a simple CD cleaner kit, one that has the little brush on it and then of course put some solution on it. Rubbing alchol will due. This happens to everyone eventually.
Should do the trick.
If it doesn't do it after playing the cleaning disk three times for around 10 secs each, then you may want to open it up and put clean the laser lens directly with a rubbing alchol soaked que tip and a dry one. For more instructions on how to open it do a search on fixya and there is one guru who goes into great detail about this.
1/22/2019 12:25:45 AM • EA - Electronic... • Answered on Jan 22, 2019
4answers
To play Rock Band without vocals?
Seriously you guys are hilarious, nobody's even given this guy a true and or correct answer. I too have had this problem and it's INFURIATING. Just trying to play the damn game: No you don't have to download anything
Solution:
Enter Game mode/ Training mode whatever mode USING THAT INSTRUMENT. I repeat DO not use the controller (the xbox360 controller) unless you want to use the microphone. It makes sense the microphone has no control hence by default if your'e using the controller the game THINKS you want to play with the microphone.
ROCK ON!!
12/25/2018 7:29:40 PM • EA - Electronic... • Answered on Dec 25, 2018
Set up rock band guitar controller
Ok time to call you all idiots and ask the most basic question, did you buy this used? If so did you get the wireless receiver dongle with it? All GH or rock band guitars require a USB receiver dongle.
2/17/2016 12:17:00 AM • EA - Electronic... • Answered on Feb 17, 2016
How do you open a ps2 slim?
Here is a complete guide with photos.
6/26/2014 1:16:15 AM • EA - Electronic... • Answered on Jun 26, 2014
2answers
I can't get my harmonix stratocaster fender
Sony blocked all third party,non Sony or not licensed by Sony hardware,with Firmware upgrade 3.5.
5/18/2013 7:36:52 PM • EA - Electronic... • Answered on May 18, 2013
My ps3 system wont register
I had a mic that wouldn't register in the ps3 for Rock Band. Tried a different mic and that worked better. Possibly a short in the wires causing it not to read.
5/3/2013 1:42:28 PM • EA - Electronic... • Answered on May 03, 2013
Does the harmonix guitar model 822151 work for wii also?
no tried it myself
1/28/2013 10:00:28 AM • EA - Electronic... • Answered on Jan 28, 2013
Why is the disk not spinning and the error msg says there is no data. I have cleaned the lens directly with alcohol
Do all your other games work? If not, it sounds like the control arm of the actual blu-ray player has worn out. Hope this helps.
9/22/2012 3:20:55 PM • EA - Electronic... • Answered on Sep 22, 2012
Is there a guitar hero foot pedal wire replacement
you will have to get a new foot pedal var fctb_tool=null; function FCTB_Init_62176759b3424b9cbe761805261ece8a(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_62176759b3424b9cbe761805261ece8a(document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316']); delete document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316'] var fctb_tool=null; function FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(document['FCTB_Init_f65b37e3b16a4105b681111044638705']); delete document['FCTB_Init_f65b37e3b16a4105b681111044638705']
5/5/2011 3:00:53 PM • EA - Electronic... • Answered on May 05, 2011
I am being told to
turn your controller off and just plug in your guitar
8/4/2010 10:57:34 PM • EA - Electronic... • Answered on Aug 04, 2010
Rock Band & GH guitar- is it possible?
Heres The Problem Scott.. When rock band was first released it was not compatible with guitar hero's guitar. only guitars from world tour forward will work with rock band
2/17/2010 4:01:55 AM • EA - Electronic... • Answered on Feb 17, 2010
Whamy bar broke
It Can be repaired.. and i found some extra parts for it online. try ebay or amazon.
2/17/2010 3:59:01 AM • EA - Electronic... • Answered on Feb 17, 2010
I set up everything correctly, but when I try to
yes its a simple fix.
go to menu
settings or calibration(depending on which game)
go to calibrate
follow the intructions of the calibration
hope that helps let me know how it goes
1/2/2010 6:56:32 AM • EA - Electronic... • Answered on Jan 02, 2010
Help!!!
hi
i think that your playstation has worn out and i personally would be going onto a site like ebay and buying a new ps2, you could pick up a cheap second hand one for 50 bucks
8/29/2009 9:32:21 AM • EA - Electronic... • Answered on Aug 29, 2009
Rock Band Drum doesnt work
This is a fualty reciepter inside the drum. I have not got this game so i dont know how to open the drum head or underside. however i have expierienced problems like this before. Either something has come loose i.e receptor or a wire. Or the receptor i broken which will mena buying a new one . I suggest pening it up and very carefully without electrcuting yourself touch the receptor and see if it make the drum work.
12/29/2008 8:50:30 PM • EA - Electronic... • Answered on Dec 29, 2008
Rockband vocals
it could be that your not using a HDMI cable.
10/14/2008 3:06:53 AM • EA - Electronic... • Answered on Oct 14, 2008
2answers
I need a fifa 12 operating manual
Check here to the complete FIFA 12 In Game ManualHope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using Fixya, and have a nice day
6/3/2019 3:18:37 AM • EA - Electronic... • Answered on Jun 03, 2019
2answers
In fifa 2002 it sys ' pls insert cd " when i instaled the cracked version.how do i fix it
You're not supposed to pirate games.
5/14/2019 6:16:54 AM • EA - Electronic... • Answered on May 14, 2019
EA - Electronic Arts Rock Band Logo
Popular Tags
21 questions posted
Top EA - Electronic Arts Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • EA - Electronic Arts Video Game Consoles & Games
Most Popular Question
play rock band without vocals
  • Video Game Consoles & Games
