20 Most Recent Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer Questions & Answers
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
4/4/2015 3:22:29 PM • Sears Kenmore... • Answered on Apr 04, 2015
Why washer has to go on spin cycle 3-4 times to get water out but still wet
your pump may be clogged or there is a clog between the tub and ejection hoses.
4/4/2015 3:17:03 PM • Sears Kenmore... • Answered on Apr 04, 2015
How to get back off of sears kenmore clothes washer
Or the washer is one piece and it lifts entirely as a shell off the base.
4/4/2015 3:15:15 PM • Sears Kenmore... • Answered on Apr 04, 2015
Why Kenmore low water wash machine dont wet parts of sheets?
Or your water level switch need replacing based on your information.
4/4/2015 3:13:49 PM • Sears Kenmore... • Answered on Apr 04, 2015
How to fix washer leaking from bottom when spenning
Might be the hose from tub to pump or pump to outside. Check each by raising the unit and do a spin cycle.
2/17/2015 1:10:30 AM • Sears Kenmore... • Answered on Feb 17, 2015
What does error code IE mean?
The "IE" error code indicates that there is a water inlet problem on an LG washing machine. This code appear's if the washer will not fill to the correct water level. There are 3 possible causes for the IE code. 1) partially or fully closed water supply lines 2) improperly attached supply hoses 3) clogged supply hose filters (on machine and in the hoses).
11/20/2014 2:26:04 AM • Sears Kenmore... • Answered on Nov 20, 2014
Sears stackable. When the washer has finnished and the knob is NOT pushed in water refills the tub when thw dryer is turned on. Is this an valve inlet problem?
valve or knob problem need to use a multi meter to test for short or failure
3/8/2022 9:02:49 PM • Sears Washing... • Answered on Mar 08, 2022
Sears 970-c47022 bearings
10/31/2021 7:23:48 PM • Sears Washing... • Answered on Oct 31, 2021
Agitator broken off in top load Sears 300 washing machine..i have manual from purchase noting model 110.2234/2244. where can I get replacement part.
That isn't a complete model number. I found three models at Sears Parts Direct that started with110.2234* . Click on the Models tab at https://www.searspartsdirect.com/search?q=110.2234 . The three machines use the same parts. The parts diagram for the Kenmore 110.22342511 top load washer here: https://www.searspartsdirect.com/model/3219xhjolw-000582/kenmore-11022342511-washer-parts . The upper agitator is given a different number on the basket diagram for some of the models. However, the current replacement is part W10836692. This is back-ordered at Sears Parts Direct. It's listed as in stock at https://www.maytagreplacementparts.com/PartDetail/Upper-Agitator/W10836692/4363274 and https://www.appliancepartspros.com/whirlpool-agitator-w10836692-ap5988691.html . Kenmore manuals almost never list the full model number. They make one for several models in a line or multiple lines. In this case, the manual covers two series: 110.2234xxxx and 110.2244xxxx washers. 110 means that the machines were made by Whirlpool with the Kenmore nameplate. Manuals Lib has a copy of this manual here: https://www.manualslib.com/manual/1327493/Kenmore-110-2234-Series.html . In the future, you can usually find the model number in one of several places on the washer. Check for the label on the back of the control panel, on the back in the upper left corner. or inside the washer on the frame under the lid for a top-load machine. There are a few other spots where the label could be but those are the most common. I hope this helps. Cindy Wells
8/3/2020 6:28:32 PM • Sears Washing... • Answered on Aug 03, 2020
What is better a vibration all body machine or a belt massage machine for circulation?
I remember the machine being featured on a tv game show causing much merriment when demonstrated by Bruce Forsyth with the aid of a contestant. I believe the machine was intended to "punish" fat cells, loosening them and making it easier for them to disappear with the aid of diet and exercise. The belt should be well within the capability of any competent handyman to fabricate from a variety of materials; nylon webbing such as seatbelts are made from, Balata belting (rubber and canvas) or thick leather... I think the jury is still out about the possible beneficial effects on circulation of wobble machines, massagers and whole body vibrations. There is reckoned to be some advantage to electrical muscle stimulation for lower leg circulation but I think a large pinch of salt should be taken with most claims. Appropriate diet and appropriate exercise is the key to many ailments, with medical supervision also if appropriate - a brisk walk to the greengrocers for fruit and vegetables to sustain you for cycling or swimming will probably do more for a person's circulation than any (dubious) machine...
6/16/2019 11:11:18 PM • Sears Washing... • Answered on Jun 16, 2019
Ineed exact measurements for sears washer 40042
use a ruler
2/22/2019 5:31:51 PM • Sears Washing... • Answered on Feb 22, 2019
Sears washer Model 110-45644291 issue with the agitator. top load. will fill then sounds like a clutch not catching and the agitator won't move. pump works, drain is fine. what should I do?
you didn't say how old it is, - but likely the cost effective solution (if it is more than 5 years old) is : buy a new washer.
3/8/2018 11:02:39 AM • Sears Washing... • Answered on Mar 08, 2018
Sears Laundry center model #417-6171 Cannot get washer to properly spin all water out of a king size pillow
If it spins all other loads out properly, then the pillow is the problem
11/12/2017 9:17:36 PM • Sears Washing... • Answered on Nov 12, 2017
2answers
Dish washer is broke, your agent came to repair. Ordered parts. Never saw the sears guy again. Now your agents say the washer is not under repair. I have paid for warrenty
Contact sears customer service with your warranty info to resolve this issue. If unit is no longer under warranty then that is a different story. Check youir manual for warranty details.
9/2/2017 1:01:46 AM • Sears Washing... • Answered on Sep 02, 2017
Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer Logo
16 questions posted
Top Sears Washing Machines Experts
john h
Are you a Sears Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Sears Washing Machines
Most Popular Question
kenmore low water wash machine dont wet
  • Washing Machines
