20 Most Recent
LG GSA-T20N DVD±RW Dual Layer Burner Questions & Answers
My computer has given me
until you no exactly what has caused the problem you cant fix
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
or you could download a registry cleaner
also
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
TO DOWNLOAD DRIVERS FOR LG GSA-T40N MULTI DVD
Windows XP/Vista/7 should automatically use its own drivers, so that you can read from CD/DVD disks.
You'll need "extra" software if you want to play a DVD-movie, or if you want to write CD/DVD disks,
e.g., 'PowerDVD' to "play", and Nero Burning to "write".
Hl-dt-st rw/dvd gcc-4240n not working
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it
using a screw driver a little anti-clockwise..clean the lens with clean
cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open
up ur system cabinet and see if all the data cables n jumper settings
at the back of the drives (master/slave selection)..itz most
important..!!
however, at the bootup (0.29sec) start pressing
briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del
as applicable)..glance in the standard settings if r detected
individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) :
Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
My disk drive doesn't detect burning media.
You MUST have software that is for burning a CD.
Some examples are "CD Creator", "Nero" and others.
These programs are OFTEN not included and MUST be purchased seperately.
