20 Most Recent
Frigidaire GSTR1670A Front Load Washer Questions & Answers
My frigidaire front load washer/rear control panel
Could be Drum bearings, try Grabbing the inner drum and moving it front to back ,should have little or NO Play, assuming this is okay then check the counter weight, Concrete Slab on top of machine outer drum loose
Drum is loud during spin cycle
A loud whinning or rumbling sound when it is in the spin cycle means that the bearings in this washer has failed. It is an expensive repair since the washer has to be torn complete apart to get to the bearings. Also, the manufacturer does not sell you just the bearings and seal but, you must buy the rear tub with the bearings which raises the cost of the repair significantly. For example the rear tub for this washer can cost $250 not including the shipping. So get a few estimates before deciding whether to repair or replacing the washer.
But, if you have the mechanical ability to do the work yourself and you are interested in getting the bearings and seal parts to get your washer going again. There is this site that has videos describing what it will take to fix this washer and will sell you the neccessary parts. The link to this site is:
http://www.hometask.com/washerrepair.aspx
Softner dispenser
The detergent dispenser is located above the detergent drawer.
A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer.
By opening upper machine's cover you will have an access to the dispenser.
Disconnect the power cable from the machine before moving to next test !!!!
Look first that they are not any disconnected wires.
Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit).
In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced.
Good luck !!
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you!
I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
What's stopping my dryer from running continuously
Please power cycle your dryer and attempt to run it again. If this fails, please ensure that your clothes are evenly distributed so that they weight of the clothes doesn't cause the dryer to be shutdown. Just to double check, please ensure that you've cleaned the lint track of your dryer. Lastly, you can use an power outlet extender to help switch the power outlet that you're using to run your dryer as there might be something wrong with your current one.
Thank you.
My Frigidaire dryer won't run longer than 5 secs what's wrong how can I fix
There could be several issues that could cause your Frigidaire dryer to stop running after just a few seconds. Here are a few potential problems to consider:
- Thermal fuse: The thermal fuse is a safety device that shuts off the dryer if it overheats. If the fuse has blown, the dryer will not run.
- Clogged dryer vent: If the dryer vent is clogged, it can cause the dryer to overheat, which could trip the thermal fuse.
- Faulty cycling thermostat: The cycling thermostat regulates the dryer's temperature. If it's faulty, the dryer may not run for more than a few seconds.
- Faulty start switch: If the start switch is faulty, it could prevent the dryer from running.
- Faulty door switch: The door switch prevents the dryer from running when the door is open. If the switch is faulty, the dryer may not run.
To fix the problem, you'll need to diagnose which of these issues is causing the problem and then replace the faulty part. I recommend having a mechanic diagnose and fix the problem for you.
WHAT IS E11 ERROR CODE IN MICROWAVE FRIGIDAIRE
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
