20 Most Recent SanDisk Sansa Clip MP3 Player Questions & Answers
Can't transfer Audible files to my Sansa Clip
The link to the operating manual (which includes the Audiobook instructions) is here:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
What I would do is drag and drop the Audible files from the folder that Audible creates to store your audiobooks to the Audible folder of the Sansa Clip, instead of using the Audible Manager.
-Tha Mp3 Doctor
12/16/2022 10:18:31 AM • SanDisk Sansa... • Answered on Dec 16, 2022
3answers
Do not know how to download
You have to download "audible manager" from audible.com. Use it to transfer audible books to your device. It's free in period time and free some books.
Good luck
12/7/2022 10:21:49 AM • SanDisk Sansa... • Answered on Dec 07, 2022
5answers
I cannot listen to an
"Audible" books are copy protected to prevent unauthorized copying or sharing.
Download the Audible Manager software from http://www.audible.com/sw
When you load that software and sign on to your Audible.com account, you will be able to sync the information into the Sansa player that will authorize the audiobook to play on the Sansa.
11/24/2022 9:03:20 AM • SanDisk Sansa... • Answered on Nov 24, 2022
7answers
Unable to download files from apple itunes
ITunes does not support this player. To put music on the player you must copy the files from the folders where the music files are on your computer to the device mounted on your computer.
9/21/2022 8:32:37 AM • SanDisk Sansa... • Answered on Sep 21, 2022
2answers
Can i use an ipod charger to charge my sansa
Having gone over a month without a response, I assume this is no longer a problem.
9/29/2021 1:51:46 PM • SanDisk Sansa... • Answered on Sep 29, 2021
Sansa clip files are write protected, can't delete songs
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
5/7/2021 5:48:06 PM • SanDisk Sansa... • Answered on May 07, 2021
4answers
How do you add songs on device
Hi atiug b...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
4/21/2020 7:13:59 AM • SanDisk Sansa... • Answered on Apr 21, 2020
Drm installation issues
DRM-protected WMA files are going to give you this problem, depending on where you got them from - it is not a defect with the player itself (a limitation, perhaps). For instance, Spiral Frog downloads will not be usable on this player. Nor will songs that do not have transfer rights.
Your best bet is to get songs that are in mp3 format - they will not give you any DRM issues.
-Tha Mp3 doctor
3/12/2020 8:38:56 AM • SanDisk Sansa... • Answered on Mar 12, 2020
I need to open my mp3
Pictures of it disassembled:
http://www.anythingbutipod.com/archives/2007/11/sandisk-sansa-clip-disassembled.php
3/1/2020 5:46:12 PM • SanDisk Sansa... • Answered on Mar 01, 2020
How to hard reset it
Reset the device first by holding in the power button for 15 seconds or longer. If this fails, download the Sansa Connect Recovery Tool from: http://www.sandisk.com/Retail/Default.aspx?CatID=1532
9/12/2019 1:59:29 PM • SanDisk Sansa... • Answered on Sep 12, 2019
2answers
How do i download music onto my Sansa Clip MP3 Player
you can try to use a youtube downloader to download videos to your Mp3, here is the one i use for long which can not only download videos from youtube but also convert videos to Mp3 while it is downloading. hope this helps for you.
4/3/2018 11:32:54 PM • SanDisk Sansa... • Answered on Apr 03, 2018
SanDisk Sansa Clip MP3 Player Logo
2,407 questions posted
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
deinstitutionalize sansa clip mp3
  • Audio Players & Recorders
