20 Most Recent
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Questions & Answers
Dishes not drying and mildew growing in dishwasher
I totally agree with Solution #1. We have a Whirlpool (apparently Maytag is the same) and it gets moldy 2 days after it has been run. The maintenance guy came out and said we had to use the rinse cycle every day. For an $800 dollar dishwasher (which is less than 1 year old!) I expect more.
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Detergent sticks in main wash compartment
Jsmarquez, We would like to inquire further about your post with you. Please respond back to this email address
[email protected] with your name, user id (Jsmarquez), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Dishwasher will not stop filling with water
Failure of the water INLET valve if fails to stop the flow or it is due to constant supply from the controller unit to the inlet valve.You can confirm this by checking the voltage on the INLET valve, if voltage is continuous it is the board and if the voltage cuts but the flow continues the valve is struck.
Timer wont advance
timer is bad. if you go to www.searspartsdirect.com , you can enter your model # and find the part #. then google the part #, you should be able to find it pretty cheap. easy to replace.
How to remove the filters
Under the bottom plate there should be a screw in filter .The top should be visible .Graspping the top turn counter clockwise into it is free. Clean and replace.I found a dish scrubber brush to be the best way too clean the. Filter
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
