20 Most Recent Syntax Olevia 226T 26 in. LCD Television Questions & Answers
0answers
How do you remove PARENTAL CONTROLS on Olevia Syntax LT26HVX when you don't have the remote? Power surge caused problem.
You need the remote, only way. You can most likely get the OEM remote or one that will work like the OEM from this website 1 800 Remotes
4/19/2017 10:54:49 PM • Syntax Olevia... • Answered on Apr 19, 2017
NO REMOTE for Olevia Syntax LT26HVX.
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/ Without a remote control, you can't unlock parential lock.
2/17/2014 4:03:16 AM • Syntax Olevia... • Answered on Feb 17, 2014
0answers
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
9/17/2013 12:21:09 AM • Syntax Olevia... • Answered on Sep 17, 2013
We have sound and no picture
You may have a backlight problem, to verify this turn on the set. Dim the lights in the room and shine a bright flashlight on the panel. Do you see a faint image?
2/9/2013 6:33:49 AM • Syntax Olevia... • Answered on Feb 09, 2013
3answers
I have my olevia 232-s12
this could be a PS3 software issue, if you can let it auto update, if the problem isnt resolved try a 720i setting or a 1080p, if still no joy your display may be on the way out
11/14/2011 1:55:04 AM • Syntax Olevia... • Answered on Nov 14, 2011
I deleted all the channels
you could try reset the tv to factory settings other than that i would sugest a new antena or getting a specialist to fix it.
7/19/2011 6:52:58 AM • Syntax Olevia... • Answered on Jul 19, 2011
Takes 15-20 minutes to warm up before picture
Bad power supply, most likely. Take the back off and look around to see if any capacitors are bulged out. These need to be replaced with the same farad value, most likely 1000uF, but the voltage can be increased a little if need be.
http://www.youtube.com/watch?v=BNHHrgX_6cs
Video demonstration.
You can get these parts at Radio Shack, or on Ebay. Just see which ones are puffed and match the value.
http://cgi.ebay.com/Olevia-226-T11-Power-Supply-DPS-161AP-2-/130528949485?pt=LH_DefaultDomain_0&hash=item1e6421b4ed#ht_500wt_917
This is the powersupply. The capacitors are the ones with the + marks in the center of the circles and may be under the heat sinks with the phillips screws.
6/24/2011 12:35:42 AM • Syntax Olevia... • Answered on Jun 24, 2011
0answers
What are the remote contol codes for an Olevia 47"
1304-1815-1802-1615-1217-Try one of these.
9/3/2010 5:12:56 PM • Syntax Olevia... • Answered on Sep 03, 2010
On my Olevia 226-T12 I
Sounds like you have a backlight related problem. Apparently the backlight is turning itself off in a few seconds.Can you confirm if you have a dull glow on the screen?
8/30/2010 3:25:50 PM • Syntax Olevia... • Answered on Aug 30, 2010
Universal remote code for comcast
Check REmote COdes here!
<a heref="http://universalremotecodes.blogspot.com/">Magnavox Universal Remote</a>
7/18/2010 7:28:25 PM • Syntax Olevia... • Answered on Jul 18, 2010
Syntax Olevia 226T 26 in. LCD Television Logo
42 questions posted
Top Syntax Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Syntax Televison & Video
Most Popular Question
olevia 226 t12
  • Televison & Video
