20 Most Recent
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Questions & Answers
My mayage centennial washer is agitating before
We had the same problem with our Maytag Centenial Washer. I simply removed the Auto Fill Sensor, cleaned the contacts with Deoxit contact cleaner and problem solved. All was done in less than 20 minutes.
11/30/2019 3:58:33 PM •
Maytag...
Answered
on Nov 30, 2019
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken.
If you are under warranty get it replaced. If not remove the top of the washer
and take out the switch assembly. The 4 wires going in are Yellow, Red, White,
and Blue. If you short the white and blue together, the washer thinks the lid
is closed. If you short the red white and blue together the washer thinks the
lid is closed and locked. The yellow is only there to activate the
electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter
of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if
you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
10/30/2017 11:38:14 PM •
Maytag...
Answered
on Oct 30, 2017
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
5/15/2017 5:10:04 AM •
Maytag...
Answered
on May 15, 2017
Watermixernotlethotflow
Dear Ed,
To save some money and effort, get an electric meter and check to wires to the water mixer to see if the electricity is coming to the mixer when you tell it to use the "hot".
Then, check the filter screen either in the hot water hose (found on either end) or the hot water connection in the mixing valve.
They can plug up with sediment preventing water flow.
Finally, you can change the mixing valve it you are sure the electricity is coming to it during the hot cycle, and you are sure the water is flowing freely out of the hot water hose.
God bless your efforts.
11/12/2015 7:52:29 PM •
Maytag...
Answered
on Nov 12, 2015
Want spin water out
The drainhose could be kinked or clogged my brother had a small stocking in his.the drainhose could be too high no more than 94 inches
Low voltage can cause this no extension cord
To much suds too much detergent us a he High Efficiency detergent
Load unbalanced a single or bulky item may cause imbalance add more item or distribute the load
7/24/2015 1:48:11 AM •
Maytag...
Answered
on Jul 24, 2015
