20 Most Recent Mitsubishi WD-Y65 65" HDTV Questions & Answers
2answers
View 3D on wd-y65
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
12/29/2021 5:39:14 AM • Mitsubishi... • Answered on Dec 29, 2021
My Mitsubishi WD-Y65 screen will not turn on. No sound will come out. It makes a noise like a high squeal, then the squeal slowly becomes lower. It sounds like an old looney tunes cartoon where wil
sound s like you have a bad color wheel the wheel spins and then the lamp lights the lamp could be bad as well
10/13/2014 12:42:45 PM • Mitsubishi... • Answered on Oct 13, 2014
manual
0answers
Tv sound buzzing lamp
Contact any service technician.
10/9/2013 4:03:34 PM • Mitsubishi... • Answered on Oct 09, 2013
I just replaced the bulb in my tv (the new bulb
After replacement of bulb, lamp reset should be done. Have you did it? If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/9/2013 4:02:06 PM • Mitsubishi... • Answered on Oct 09, 2013
0answers
0answers
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:First is this is a DLP set and the lamp may have failedSecond is it should have the self check which reads error codes---most of these sets that is the same:" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.(then release both) The Power light will start to flash in a two digit sequence. For example, 3 flashes, then 7 flashes = 37. Here are the error codes, and the corresponding problem: 12 = No error detected, check power supply. 32 = Lamp Cover is open. 33 = Air filter cover is open. 34 = Lamp abnormality 36 = Light Engine (DMD or Lamp Fan stopped) 37 = Exhaust or Lamp Ballast Fan stopped 38 = Lamp Temperature High 39 = DMD Temperature High 41 = Short is detected 44 = DVI cable between FMT and Engine disconnectedThis is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.If you get the lamp abnormal it is likely your problem.
12/6/2012 3:33:31 AM • Mitsubishi... • Answered on Dec 06, 2012
2answers
My y65 has a new
ogrady1428,
I would check the filter on the fan intake first. Remove it and carefully clean it with compressed air.If this does not resolve your problem then I would remove the lamp and inspect the switch in the vicinity of the door for problems. Be very careful reassembling the unit once the door is removed. The interlock swich must be positioned correctly or you will get an error message. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem and how to fix it.
Thanks for using FixYa and for the generous rating. We answer these questions for free.
hardrocko
10/6/2012 4:22:03 PM • Mitsubishi... • Answered on Oct 06, 2012
Light sensor
Time to buy a new one.
6/27/2012 7:52:00 PM • Mitsubishi... • Answered on Jun 27, 2012
Wd-y65 no picture. Sound for a few seconds then shuts off
Lamp is usually customer replaceable and instructions are in owner manual.I would to begin with (set unplugged) get at the lamp to inspect it--if shattered inside look for a replacement.Google the model number with "lamp" to see what is available.You Tube has video instructions for replacing lamps on most brands and models as well---not have to read just look.
5/22/2012 4:34:11 PM • Mitsubishi... • Answered on May 22, 2012
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
1/31/2012 3:20:58 AM • Mitsubishi... • Answered on Jan 31, 2012
What hook ups do I need for the tv i moved I lost
what are you trying to connect to this tv?
8/22/2011 9:06:51 PM • Mitsubishi... • Answered on Aug 22, 2011
Mitsubishi WD-Y65 65" HDTV Logo
57 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
tv turned off itself one day pressed
  • Televison & Video
