20 Most Recent Karcher 2500 PSI Pressure Washer Questions & Answers
4answers
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
8/7/2022 5:26:57 AM • Karcher 2500 PSI... • Answered on Aug 07, 2022
2answers
Changing pump oil on ryobi pressure washer model ry80030
Just bought one of these for $100 on craigslist with out knowing anything. After 5 mins of use the pressure was varying all over the place and the pump binding up to the point white clouds of smoke where coming from exhaust. After tons of online research w/o success I just figured I had nothing to loose so I tried my own fix and now I have over 3 hours of solid use stripping old paint from house with out a single issue. All I did was 1 ) Remove the black screw off tube pointing up on water pump. ( was caked with gritty oil deposits) cleaned out old oil. 2) Used red hot nail to put single hole threw center of top 3) Re- Install tube 4) Took a Manual 8" Multi Sports Ball Air Pump with Inflation Needle and removed the top to poor in Oil then re-sealed ( I used old Mobile 1 0/20 synthetic from my last oil change ) 5) Injected oil with pump threw center hole, you will feel the pressure build up and then feel and hear the oil rushing threw to the pump 6) I placed a Plastic Round Cap Roofing Nail threw the hole to help keep out water. Simple fix but it saved my $100 investment as the pump now is running strong with great pressure!
5/19/2022 5:52:20 PM • Karcher 2500 PSI... • Answered on May 19, 2022
Cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
9/28/2018 4:01:13 AM • Karcher 2500 PSI... • Answered on Sep 28, 2018
4answers
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
1/2/2018 6:40:07 PM • Karcher 2500 PSI... • Answered on Jan 02, 2018
I have a honda pressure with a honda 160
did you forget to shut off the fuel before moving your pressure washer? It sounds like the engine is flooded. Honda GX engines are famous for flooding with the fuel valve left on when moving. Or did you store it in a tilted position? Take the spark plug back out and pull the pull rope a few times...you should see the gas that flooded ejected from the plug hole. Once you feel you got all the gas out, replace the plug. You may want to check your oil and make sure it isn't full of gas now also. If it is good, or you have changed your oil then start it up....It should not have the resistance anymore and should start just fine. Good luck
9/12/2017 7:14:59 PM • Karcher 2500 PSI... • Answered on Sep 12, 2017
Carburator is gummed up I can remove the
leaving fuel in a bowl will cause corrosion in the jets and jam the needle and seat operation take the carby off the machine and go to a shop that can overhaul the unit
6/29/2017 10:17:19 AM • Karcher 2500 PSI... • Answered on Jun 29, 2017
4answers
Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
3/31/2017 12:25:02 PM • Karcher 2500 PSI... • Answered on Mar 31, 2017
Drained the gear oil out of pump
Yes, fill'er up.
3/4/2017 12:59:35 AM • Karcher 2500 PSI... • Answered on Mar 04, 2017
Why does my 2014 ktm250sxf keeps bogging out of corners can you help
Try cleaning air filter, excessive dirt build up, over oiled filter, next check wire harness kill switch etc. fuel pump,
8/6/2016 5:10:03 AM • Karcher 2500 PSI... • Answered on Aug 06, 2016
Replacing manifold on troy bilt pressure washer
I was able to forcefully push it back until it clicked.
4/2/2016 3:20:13 PM • Karcher 2500 PSI... • Answered on Apr 02, 2016
8answers
Simoniz S1400 Electric Pressure Washer
check out www.pressureparts.com
2/16/2016 10:55:38 PM • Karcher 2500 PSI... • Answered on Feb 16, 2016
Karcher 2500 PSI Pressure Washer Logo
Popular Tags
805 questions posted
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
above ground pool repaired
  • Garden
