20 Most Recent Sony Cyber-shot DSC-T10 Digital Camera Questions & Answers
How do you repair E:62:10 error message on SONY
Hello,I'm sorry but this error code has nothing to do with Windows software or memory card error as indicated above. The list of error codes can be found at https://www.sony.com.au/electronics/support/articles/00008857 : E:62:10 is a very well known and recurring problem with a lot of Sony camera's and indicates failure of the stabilizer. I found more than 300 forums discussing the problem, please read http://sony-e-62-10.atspace.cc/. A temporary solution is available on https://www.youtube.com/watch?v=S53D3EfDVk0. Hope this helps.
2/2/2019 11:22:11 AM • Sony Cyber-shot ... • Answered on Feb 02, 2019
2answers
Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
1/27/2019 8:37:21 AM • Sony Cyber-shot ... • Answered on Jan 27, 2019
4answers
Sony DSC-T10 Cybershot vibration problem
I have the same problem with my Sony T-10. I brought it to a Laker game and it started vibrating in shoot mode. I think because it was so loud during the game when I did try to take a picture, it came out blurry. I shook it a couple of times and it went back to normal. I tried to take a picture in the car and at home, no vibration. I tried it in a night club, where it was loud...and the vibration came back.
There is a sensor in the camera that cannot focus on shooting under loud environment. I took the camera back to best buy for repair...and they said they have heard of such a problem. This is an internal damage inside that needs repair.
1/27/2019 8:34:20 AM • Sony Cyber-shot ... • Answered on Jan 27, 2019
Error of E 62 20 PD 177 camera
Hello, The official list of error codes can be found at https://www.sony.com.au/electronics/support/articles/00008857 : E:62:20 indicates failure of the stabilizer, something that is unfortunately very frequent and recurring problem with all sorts of Sony camera's. I found more than 300 forums discussing the problem, please read http://sony-e-62-10.atspace.cc/. A temporary solution is also available on https://www.youtube.com/watch?v=S53D3EfDVk0. Hope this will help you.
1/27/2019 8:26:58 AM • Sony Cyber-shot ... • Answered on Jan 27, 2019
3answers
My camera is really blurry;
Press the reset button on the bottom of the camera. Then power the camera off, and power it back on again. "I have a DSC-P50 and was encountering the same problem. I went in to the camera set-up mode with the memory stick removed and changed serveral options (Don't remember which ones, although I do remember trying to change the "Format" setting) When I re-inserted the memory stick, the camera worked. " E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
Hope helps.
11/25/2018 7:30:32 AM • Sony Cyber-shot ... • Answered on Nov 25, 2018
2answers
I have a flashing E:62:10
Hi Rajesh,I have come across this problem earlier , and would seems as a weird thing to do but works, what you need to do , is remove the batteries and hit on the side of the camera with your palm and then try to put the batteries back in and then restart the camera , if that does not work , you need to get it done via the service center as this problem is associated with a gear of the lens and can be corrected by professional tools.Hope that helps ...:)
11/25/2018 7:01:22 AM • Sony Cyber-shot ... • Answered on Nov 25, 2018
6210 error message
You have the same problem as many other users with Sony camera's. Error codes can be found at https://www.sony.com.au/electronics/support/articles/00008857. Read my story at http://sony-e-62-10.atspace.cc/. A temporary working solution is at Sony 62 10 English
11/25/2018 6:59:50 AM • Sony Cyber-shot ... • Answered on Nov 25, 2018
12answers
Indication E:62:10
I had the same error- I tried wacking it against my leg- and now it works again!!! thank you!
11/25/2018 6:56:27 AM • Sony Cyber-shot ... • Answered on Nov 25, 2018
2answers
T10 kept vibrating and show E:62:10?
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
11/11/2018 9:37:01 AM • Sony Cyber-shot ... • Answered on Nov 11, 2018
2answers
I have a flashing E:62:10 warning on the screen
Try to use the default settings of the camera and it can solve your problem.
11/4/2018 6:56:32 AM • Sony Cyber-shot ... • Answered on Nov 04, 2018
2answers
Blinking notice on screen E:62:10
E:62:10 means one of the flat cables is loose that leads to the imaging module. Remove the battery and memory card. Remove the five screws and open the camera by lifting the front off. There will be a black plastic sheet lightly glued slightly to the tight of center. This covers two connectors for flat connectors. each has a tiny black hinged bar that can be popped uo with a small flat blade. Then slide the connecter as deep in the socket as possible. Snap the retaining bars back down and replace the black plastic insulator. Reassemble camera.
While you have the camera open canned air can be used to get any lint or dust out of the camera while it its open.
11/4/2018 6:55:20 AM • Sony Cyber-shot ... • Answered on Nov 04, 2018
2answers
Remove a flashing code
E62:10 errer related to lens unit problum i think some internal dislocations or gears problum this is repairable
11/4/2018 6:52:51 AM • Sony Cyber-shot ... • Answered on Nov 04, 2018
2answers
Hi I have a Sont Cyber-Shoot DSC-T10 camera but it
A letter and number error code of E:61:xx , E:62:xx , or E:91:xx is an indication a malfunction has occurred in the camera. To try resolving any of these error codes, power reset the camera back to the original factory specifications.
I'll forward a link to a page where you can view the information about power resetting the Camera.
Please click on the link to open the page to view the troubleshooting steps.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
Thank You!
11/4/2018 6:51:17 AM • Sony Cyber-shot ... • Answered on Nov 04, 2018
2answers
My dsc-t10 camera shows e:62:10
My dsc-t10 camera shows e:62:10 Problem with the Sony Cyber-shot DSC-T10 Digital Camera
11/4/2018 6:47:09 AM • Sony Cyber-shot ... • Answered on Nov 04, 2018
6answers
E:62:10
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
10/29/2018 6:17:42 PM • Sony Cyber-shot ... • Answered on Oct 29, 2018
Blank white screen
It should take pictures fine. Sqeeze the camera hard at the bottom while watching the screen.
8/29/2017 8:34:28 AM • Sony Cyber-shot ... • Answered on Aug 29, 2017
Camera DSC-T10 doesn't turn on
Since this is now some twelve years old, it has probably reached the end of its working life.
5/26/2017 7:47:17 AM • Sony Cyber-shot ... • Answered on May 26, 2017
What settings for underwater photos
Most camera's are not made to shoot under water. One of the most important things is an extended possibility for the white balance. Most DSC-T camera's only have some standard settings here, for daylight, cloudy and some light sources, like incandescent and fluorescent. So even when you have a under water housing, you can't setup the camera for shooting under water. Sorry. Try a ruggedised camera, they are not that expensive and have everything you want.
2/25/2015 4:09:30 PM • Sony Cyber-shot ... • Answered on Feb 25, 2015
Manual fof Sony DSCT10
You may download the manual and more from Digital Still Camera Silver
1/3/2015 5:17:32 PM • Sony Cyber-shot ... • Answered on Jan 03, 2015
Sony Cyber-shot  DSC-T10 Digital Camera Logo
132 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
e 62 10
  • Cameras
