20 Most Recent Westinghouse SK-32H240S Television Questions & Answers
I had cc on and turned it off but I have 3 words that wont go away
Let it be there.
9/6/2016 4:25:50 AM • Westinghouse... • Answered on Sep 06, 2016
Westinghouse 32 inch tv just turns off after 2 or 3 days of use
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/29/2016 5:11:21 AM • Westinghouse... • Answered on May 29, 2016
2answers
Picture too large for screen
mine did not fix, picture is still huge and pushed to bottom of screen so the top is black all the way across
/uploads/images/picture-large-screen-34901330-4-1.jpg
1/24/2015 6:02:51 AM • Westinghouse... • Answered on Jan 24, 2015
Im not sure what happen to my tv but i came home one day and turned my tv on and it came on for 5 mins then went black but you can still here sound it does the same thing every time i turn it on and t
Is it under warranty? Have you tried to contact Westinghouse? Or the place you bought it? Did you register the TV? Those are all places to ask.
11/21/2014 9:18:23 PM • Westinghouse... • Answered on Nov 21, 2014
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps regards shaun
5/18/2014 5:02:28 AM • Westinghouse... • Answered on May 18, 2014
0answers
2answers
Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
This model has what are called a LIPS board in it which is a board that has both the power supply and the inverter on the same board. What you need to do is replace this part and your TV will be as good as new. To obtain this board simply email [email protected] and they will let you know price and availability of this board. Please make sure to include model#, serial#, and TW#, all located on the back of the unit.
1/10/2014 9:40:04 PM • Westinghouse... • Answered on Jan 10, 2014
0answers
Bad color
Be the first to answer 12/19/2013 8:46:05 PM • Westinghouse... • Posted on Dec 19, 2013Be the first to answer
Westinghouse SK-32H240S has no picture.
yes there is something wrong with the board
10/8/2013 6:24:27 PM • Westinghouse... • Answered on Oct 08, 2013
Won't turn on
b7d051c6-2386-46f1-9de1-bf708dde078e.jpgThis is often caused by failing or failed capacitors in the power supply unit (PSU). In my case I had a Lexsor 32 inch LCD flat screen (psu part number KAS200-5S241812XS VER A2.1) but these notes probably also apply to any number of similar LCD flat screen TVs with similar problems. Make sure and double check the values of any components you replace against your own TV's. The component values I have given are just for my make and model of TV.Naturally these instructions should only be used by fully competent persons who know what they are doing and anything you do is entirely at your own risk. If you do not feel competent to look inside your TV and do the repairs yourself then maybe consider printing these notes and giving them together with your TV to a fully qualified and certified TV repair specialist.Here's what happened to my TV and how I fixed it:The blue front light came on when my TV was turned on but there was no display or sound. Sometimes repeatedly pressing the on/off button many times finally got the TV to turn on but it made a buzzing / hissing / static crackly noise and it took many minutes until the LCD display and sound came to life. Eventually even repeatedly pressing the on/off button failed to work and only the blue light on the front panel came on with no other activity.CAUTION: MAKE SURE YOUR TV IS UNPLUGGED FROM THE MAINS AND *NOTE* THERE ARE VERY HIGH VOLTAGES THAT MAY STILL BE PRESENT INSIDE THE TV EVEN AFTER IT IS SWITCHED OFF AND UNPLUGGED FROM THE MINS POWER SOCKET. TAKE VERY GREAT CARE NOT TO RECEIVE AN ELECTRIC SHOCK. MAKE SURE YOU REALLY KNOW WHAT YOU ARE DOING *BEFORE YOU DO ANYTHING*! I opened the TV and located the PSU board (see photo). Six of the electrolytic capacitors were clearly puffed at the top (your TV may have a different number of capacitors that need replacing). They should all have flat tops so if they look "puffed up" (a bit like a bottle of fizzy pop that's been shaken) then they need replacing.Please note that in my PSU three of the capacitors were orange 25v 680uF electrolytic radials and three were black 35v 680uF electrolytic radials. I un-soldered the capacitors from the board and replaced them all with 35v black 680 uF electrolytic capacitors (I reckon the few extra pence the 35v ones cost instead of the 25v ones is money well spent!)Re-assemble the whole thing and - there you go - I hope you are as lucky as me and your TV is as good (or better) than new!Happy viewing!
9/18/2013 5:06:10 PM • Westinghouse... • Answered on Sep 18, 2013
Televison & Video Logo
195 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
westinghouse tv model number sk 32h240s
  • Televison & Video
