20 Most Recent Sony Cyber-shot DSC-S700 Digital Camera Questions & Answers
2answers
Cyber shot dsc-s700
I have the same problem. In this case, the main circuit (not flash circuit) doesn't work. I have had the oportunity for try with another main circuit and then, the camera turned on.
2/28/2022 2:26:52 PM • Sony Cyber-shot ... • Answered on Feb 28, 2022
2answers
I need to download a sony cybershot DSC-S700
you can download the pictures in a very easy way by using a card reader. buy one and take the memory card out of the camera and put it inside the reader.
it has a USB connection and does not need a driver.
1/20/2016 7:40:16 AM • Sony Cyber-shot ... • Answered on Jan 20, 2016
How do you remove the battery cover on sony cybershot dsc s700 or where can I find instruction.I need help. Thanks Bob
When it is not in the user manual, you should not try this. Modern electronics are difficult to repair. When you try to remove something from a digital camera, it could be not even the certified repair centres will accept it for repair. So unless you already wanted to trow it away, please don't doe this.
2/18/2015 12:03:27 PM • Sony Cyber-shot ... • Answered on Feb 18, 2015
2answers
Camera does not read sd card
format the SD card from computer and then insert it Camera. Now see . if not reading then try other card. If the other card not read by camera then its a camera firmware fault.
11/22/2014 7:50:17 AM • Sony Cyber-shot ... • Answered on Nov 22, 2014
3answers
How to delete all the pictures on my camera.
re format you memory card in camera it should be in menu then settings then memory try it
2/6/2014 5:39:58 AM • Sony Cyber-shot ... • Answered on Feb 06, 2014
6answers
Flash not working
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
1/11/2014 4:47:29 PM • Sony Cyber-shot ... • Answered on Jan 11, 2014
Lines on the display
If the lines are on the display all the time, but you can't see any line on any picture when you view it on a computer, the display is defect. If you can live with that, leave it that way, because most of the time a repair can cost as much as a new camera. If you try to make a picture in the dark and one or more strong lights are in the frame, that can cause white lines too, but they will be gone, as soon as you are in normal light again.
12/27/2013 1:50:46 PM • Sony Cyber-shot ... • Answered on Dec 27, 2013
6answers
Retrieving deleted photos from a sony cybershot dsc w30 digital camera
I have had success with this... Download this photo recovery software called asoftech photo recovery, follow the steps herehow to recover deleted photos from cameraYou have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.You need to use a card reader either one already in your computer (some have one, some don't). Or buy an external USB card reader. They are around $2 on Amazon.
10/23/2013 6:20:41 AM • Sony Cyber-shot ... • Answered on Oct 23, 2013
Set date time
if the memory battery is weak the dates cannot be stored properly.Do not remove battery if you want the old date to remain there
10/17/2013 6:24:50 AM • Sony Cyber-shot ... • Answered on Oct 17, 2013
3answers
I deleted the photos from
I'd recommend that you download this camera photo recovery program called asoftech photo recoveryhttp://www.asoftech.com/apr/You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
9/26/2013 2:07:33 AM • Sony Cyber-shot ... • Answered on Sep 26, 2013
2answers
I USE TO HAVE A
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
8/31/2013 4:24:33 AM • Sony Cyber-shot ... • Answered on Aug 31, 2013
I have sony DSC W530
No! it is not designed to work in that fashion, you need an open source web cam to do the job.
7/2/2013 10:50:42 AM • Sony Cyber-shot ... • Answered on Jul 02, 2013
When I go to turn on my Sony Cybershot DSC-S700 it says it's in USB Mode but it's not connected to a computer and won't let me take pictures???
I would try to plug in your usb cord to the camera and computer and then disconnect it after.. that should reset it.
11/5/2012 3:58:22 PM • Sony Cyber-shot ... • Answered on Nov 05, 2012
Hi. in my Sony camera DSC-S700 i change the photos size ,i have it now smaller but i can't remember how i do it? can u help me? Thanks
In the shooting mode, press the trashcan button just below and left of the cursor pad then select the desired image size.See page 24 of the Cyber-shot Handbook.
10/23/2012 8:58:19 PM • Sony Cyber-shot ... • Answered on Oct 23, 2012
What's your problem?Hi how can i wright automatically date & time on the photos in my Sony camera DSC-S700
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
10/23/2012 7:44:17 PM • Sony Cyber-shot ... • Answered on Oct 23, 2012
Can we use sony cyber sort DSC-W530 as a web cam
Take a look at this.
9/7/2012 9:17:56 PM • Sony Cyber-shot ... • Answered on Sep 07, 2012
Just returned from vacation..47 photos will not download to computer. Camera says file is empty, but sometimes I can see a few of them!
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTERIf your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
7/23/2012 5:21:50 AM • Sony Cyber-shot ... • Answered on Jul 23, 2012
Sony Cyber-shot  DSC-S700 Digital Camera Logo
385 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
lines display
  • Cameras
