20 Most Recent Sony Cyber-shot DSC-H7 Digital Camera Questions & Answers
Sony dsc-h7 E:61:00 error
Below is detail of Error f8b5q9ipcdnk0yaaaaasuvork5cyii= Procedure how to replace Lense dwbfbffpyq5kaaaaaelftksuqmcc i2cie0ly39aaaaabjru5erkjggg== Now you can get every thing related to fault. Kind regards.
10/18/2017 12:14:06 PM • Sony Cyber-shot ... • Answered on Oct 18, 2017
Dispaly of E:62:12 on display sceen
It is not a setting, it is an error message telling you that the camera is damaged
6/23/2017 7:52:11 PM • Sony Cyber-shot ... • Answered on Jun 23, 2017
2answers
My flash went out on my (DSC H7) Sony Cyber Shot camera I need a replacement
If the built in flash is not working it might just not be worth repairing. Sony products when they are working are great but when they go down they can be a bear to fix and the cost is usually prohibitive when you combine the labor along with the price of the part. Taking those cameras apart is real nasty business, with lots of real tiny screws and ..............U can either get a new camera or replace it with a used, working one on ebay - that is what I did.
9/5/2015 2:14:47 AM • Sony Cyber-shot ... • Answered on Sep 05, 2015
How can I fix the
The E:61:00 error code displayed on the Camera screen indicates that a Camera malfunction that you cannot reverse has occurred. This seems to be an internal malfunction of the Camera. You may try resetting the Camera by pressing the RESET button located at the base of the Camera. You can use any sharp pointed objects like ball pen or paper clip for resetting the Camera.
You may also try power resetting the Camera. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, service may be required as this is an internal malfunction
Thanks for using FixYa.
1/14/2015 8:21:28 AM • Sony Cyber-shot ... • Answered on Jan 14, 2015
Where does the USB cable plug in to the camera?
24985954-h2fs4xmf3wki3cecpzu53sb1-2-0.jpg It's a multi connector. You should have it with the package in the camera box. here is the link for the manual. https://docs.sony.com/release/DSCH7_Handbook.pdf
12/10/2014 10:30:54 AM • Sony Cyber-shot ... • Answered on Dec 10, 2014
How do I connect a USB cable to the camera?
All Sony brand of cameras feature USB ports. Check the camera for markings/ indicators on the body. It would sometimes be covered by a flap or cover that requires manual opening.
8/22/2014 5:22:22 AM • Sony Cyber-shot ... • Answered on Aug 22, 2014
Download photos
I cant get the pictures in the camera to save to the memory card it says no pictures but I see the pictures in the camera
9/7/2013 7:03:21 PM • Sony Cyber-shot ... • Answered on Sep 07, 2013
manual
Settings
Follow the instructions beginning on page 40 of the Cyber-shot handbook: http://www.docs.sony.com/release/DSCH7_Handbook.pdf
5/28/2013 8:45:50 PM • Sony Cyber-shot ... • Answered on May 28, 2013
Sony h7 show date on pcitures
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
4/18/2013 5:47:09 PM • Sony Cyber-shot ... • Answered on Apr 18, 2013
How do i change the region to U.S so i can change the language from japanese to english
Press the HOME button, select the toolbox icon, then select the last item on the menu.
10/15/2012 5:23:35 AM • Sony Cyber-shot ... • Answered on Oct 15, 2012
Creating folders on sony sc-h7
Try this:Press the "home button". Press the right button three times so you are on the memory tool area. Then press the center button. Then press the right button and then press the down button once to get to the "Create Rec. Folder" and then press enter. Now you have a new folder. To switch to a new folder, click on "Change Rec. Folder". Now any new pictures you take will automatically go into the new folder you made/selected.
8/14/2012 10:50:07 AM • Sony Cyber-shot ... • Answered on Aug 14, 2012
How to convert sony cybershot DSC H7 from japanese to english?please help !!!!!
Press the HOME button to bring up the home screen. Select the toolbox, then select the "A" icon.
7/13/2012 5:44:16 AM • Sony Cyber-shot ... • Answered on Jul 13, 2012
Ow do I set a timer
Sorry, the camera only gives you a choice of no delay, two-second delay, or ten-second delay. The full details are on page 17 of the manual.
3/23/2012 4:33:12 PM • Sony Cyber-shot ... • Answered on Mar 23, 2012
0answers
E:91:01
The error message indicates that there is malfunction occurred. Please perform a power reset by removing the battery and reinserting it after 2 minutes. If the issue persists, service may be required.
3/5/2012 12:33:15 AM • Sony Cyber-shot ... • Answered on Mar 05, 2012
Sony Cyber-shot  DSC-H7 Digital Camera Logo
125 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
change region u s change language from
  • Cameras
