20 Most Recent Sony Cybershot S650 Digital Camera Questions & Answers
Blurred photos - Sony Cyber-shot S600
It may be that the infra red sensor needs cleaning or is covered with something like fluff or grease from sun cream. This would prevent it seeing clearly in lower light conditions.
5/19/2019 10:05:16 AM • Sony Cybershot... • Answered on May 19, 2019
I can no longer download the photos from my cybershot onto my pc
Plug the USB lead directly into the computer, not via a hub
6/6/2017 7:17:57 AM • Sony Cybershot... • Answered on Jun 06, 2017
When i plug in the
Try NOT connecting your camera to your computer. The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/19/2014 5:32:10 PM • Sony Cybershot... • Answered on Nov 19, 2014
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again. Here is the error list from the camera manual. This is all I can suggest from here. "Reinsert the Memory Stick Error" • Insert the "Memory Stick Duo" correctly. • The inserted "Memory Stick Duo"cannot be used in your camera (See below). • The "Memory Stick Duo" is damaged. • The terminal section of the "Memory Stick Duo" is dirty Compatible cards. Memory Stick Duo (without MagicGate) Memory Stick Duo (with MagicGate) *1 *2 MagicGate Memory Stick Duo *1 Memory Stick PRO Duo *1 *2 --- NOT compatible Memory Stick (without MagicGate) Memory Stick (with MagicGate) MagicGate Memory Stick Memory Stick PRO ---- Some Memory Stick Duo have a write protect switch on the back. You cannot record, edit or delete images if you slide the write-protect switch to LOCK with a fine-tipped object *1 "Memory Stick Duo", "MagicGate Memory Stick Duo" and "Memory Stick PRO Duo" are equipped with MagicGate functions. MagicGate is copyright protection technology that uses encryption technology. Data recording/playback th at requires MagicGate functions cannot be performed with this camera. *2 Supports high-speed data transfer using a parallel interface.
10/13/2014 6:09:58 PM • Sony Cybershot... • Answered on Oct 13, 2014
Standby button
Replace the standby button.costs approx. USD30.00 including Air mail charges.mail to us if you need [email protected] or [email protected]
10/17/2013 6:03:23 AM • Sony Cybershot... • Answered on Oct 17, 2013
manual
I have A sony Cybershot Camera and i cant get the
Don't connect your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program,such as Picasa ( http://picasa.google.com ).
6/30/2011 6:58:09 PM • Sony Cybershot... • Answered on Jun 30, 2011
Im getting a blue screen
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
5/1/2011 10:37:20 PM • Sony Cybershot... • Answered on May 01, 2011
I need to upload picture
Consider NOT using the USB connection.
4/13/2011 6:17:21 PM • Sony Cybershot... • Answered on Apr 13, 2011
I own a Sony Cybershot
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2/23/2011 9:48:23 PM • Sony Cybershot... • Answered on Feb 23, 2011
IMPORTING PICTURE FILES FROM MY SONY CYBERSHOT
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program, such as iPhoto.
10/20/2010 7:11:50 PM • Sony Cybershot... • Answered on Oct 20, 2010
Lens will only go out
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
9/28/2010 8:23:48 PM • Sony Cybershot... • Answered on Sep 28, 2010
Sony camera lens problem
https://eservice.sony.com/webrma/web/index.do
The above is the service website for sony.com.
8/27/2010 9:22:12 PM • Sony Cybershot... • Answered on Aug 27, 2010
Camera says error formatting memory stick
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
8/27/2010 2:31:31 AM • Sony Cybershot... • Answered on Aug 27, 2010
How do i get the video from internal memory
Go into the menu and find "copy". You should have the option to copy the internal memory to a memory card.
8/18/2010 2:45:09 AM • Sony Cybershot... • Answered on Aug 18, 2010
I have DSC-W90. When I
There is sensor inside lens mechanism that sends mechanism initialize signal to system control chip of camera, if that signal is missing due to defective sensor, system control chip try three times to extend and retract lens mechanism then activate protection mode and shows error message on lcd screen as you see it "turns power off and turn it On again"
Lens assembly need to be replaced in your DSC-W90 camera to fix the problem.
Let me know if you need part number of lens assembly for this camera or take it in local camera repair shop for fix.
Hope these info will help you.
Thanks.
7/20/2010 1:05:04 AM • Sony Cybershot... • Answered on Jul 20, 2010
I have a sony cyber
Base from the description of your problem here, it seems that the problem is with your memory card, so we can try to do here first is to get any files that you have from that memory card by connecting it to a card reader and once done you can now format first the memory card that you have and check if that fix the problem. But if still not I will advice you to try a different memory card and check if the problem will be solve with a different card.
6/21/2010 6:12:48 PM • Sony Cybershot... • Answered on Jun 21, 2010
After taking a picture my previous pictures won't
There could be 2 issues here:-
1) A problem with you memory card, try re-formatting it or another card to see if its the camera or the card. Please note formatting will erase all data.
2) It could be a firmware issue, that would require you going to the Sony website following links for support and/or downloads to see if there's a firmware upgrade for you camera.
4/10/2010 1:03:07 PM • Sony Cybershot... • Answered on Apr 10, 2010
Bonjour,
http://support.sony-europe.com/dime/digistill/cyber/cyber.aspx?site=fr&m=DSC-S650&site=odw_fr_FR&odw_model=DSC-S650
voir ici pour software and manual
3/2/2010 2:14:28 PM • Sony Cybershot... • Answered on Mar 02, 2010
Sony Cybershot S650 Digital Camera Logo
140 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
own sony cybershot
  • Cameras
