20 Most Recent Westinghouse LTV-27w6 27 in. LCD HDTV Questions & Answers
WHAT ARE WESTINGHOUSE TV REMOTE CODES
Visit this site. http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf
3/4/2015 1:30:13 AM • Westinghouse... • Answered on Mar 04, 2015
2answers
Its broken, where can i
Sorry this tv is not worth a whole tv anymore.The tvs LCD screen panels are limited in productions by the tvs corporations.By replacing the tv LCD screen panel,will cost the same as a new tv.The tv LCD screen panel is 90% important to the tv.If it damages or broken than the tv only can be worth as a salvages tv for it electoronic boards for parts,that it.
1/25/2015 7:41:35 PM • Westinghouse... • Answered on Jan 25, 2015
0answers
0answers
Id/4655vx
Be the first to answer 12/14/2013 10:45:50 PM • Westinghouse... • Posted on Dec 14, 2013Be the first to answer
0answers
2answers
Blue screen for a second after power on and then black screen again
Check where your plug go's in to your powersupply if it is well fitted. ////sometimes it dosnt make well connection then you will struggle to get it on.
4/15/2013 2:45:00 AM • Westinghouse... • Answered on Apr 15, 2013
2answers
Horizontal lines
needs pwr adj.....
12/29/2012 3:13:41 PM • Westinghouse... • Answered on Dec 29, 2012
2answers
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
10/31/2012 11:32:11 PM • Westinghouse... • Answered on Oct 31, 2012
2answers
Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
1/28/2012 4:55:10 AM • Westinghouse... • Answered on Jan 28, 2012
Tried hooking up my tv to the satellite cable but
I think I see what happened here. Normally you have the tv cable connected to one connector and satellite or others to different connectors. When you want to switch you use your remote or the tv controls to change the source.This will preserve the scanned channels as well. On your remote you should see source or something like that. As you select it it should shows options like antenna, cable aux1 aux2 and so on.
So hook your tv up and rescan your channels. Then hook up the satellite to one of the other inputs. Then use the remote to switch the source. You will never see more than one sateliitel channel at a time and you will have to use the satellite remote to change channels on the satellite box.
9/26/2011 3:12:20 AM • Westinghouse... • Answered on Sep 26, 2011
2answers
I have a W TV
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
6/17/2011 1:24:23 PM • Westinghouse... • Answered on Jun 17, 2011
2answers
Light goes blue to orange,
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for blown fuses burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. you have to this with the help of multimeter to read...
- You can look at the sample of the power supply board, the picture with the soldering side has labeling of what you should have on the output of the power supply, yours may be labeled on the top side of the board, there are high voltage on the board so you must be real careful, if you are not sure, let the professional handle it.
Good luck in solving the problem.....
5/31/2011 8:38:03 PM • Westinghouse... • Answered on May 31, 2011
The light on my westinghouse
Replace the main unit board.
11/1/2010 1:40:07 AM • Westinghouse... • Answered on Nov 01, 2010
0answers
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
77 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
light goes blue orange
  • Televison & Video
