20 Most Recent GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Questions & Answers
GE side by side lock button on refrigerator cannot reset it.
To Lock and Unlock the Dispenser To lock, press and hold the ICE OFF/LOCK pad for 3 seconds. Repeat this step to unlock the dispenser. (Hold 3 sec to lock control) Appliance 911 Sea Breeze
7/24/2019 2:44:28 PM • GE Profile... • Answered on Jul 24, 2019
0answers
Panel beeping and nonresponsive
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly. Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting. Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place. Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light. ·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out. Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire. Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
12/24/2016 12:45:31 AM • GE Profile... • Answered on Dec 24, 2016
OUR REFRIGERATOR HAS A ALARM GOING OFF WITH A ERROR CODE LC ER
this sounds like the door alarm- it occurs after the door is open (or the switch has failed) for more than 2 minutes. Remember that both doors have one and also turn on/ off the lights which may or may not be tied together.
11/19/2016 6:04:16 PM • GE Profile... • Answered on Nov 19, 2016
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
10/30/2016 2:50:38 PM • GE Profile... • Answered on Oct 30, 2016
Doors won't stay shut
There are adjusters on the front leveler feet that need to be extended so the refrigerator tilts slightly back. This will keep the doors shut
6/11/2016 4:10:24 PM • GE Profile... • Answered on Jun 11, 2016
My ge pfs22s1sss is not defrosting, tested temp sensor, heating element,both ok. Evaporator thermistor tested bad, now compressor will not run
You could have a bad control board. These are notorious for going bad. I had the same issue just the other day. I replaced the control board because the compressor wasn't coming on and the defrost thermistor was also bad causing no defrost. Remove the control board and see if there are any burned spots on the back of the board.
4/28/2015 6:45:17 PM • GE Profile... • Answered on Apr 28, 2015
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
3/6/2015 8:22:44 PM • GE Profile... • Answered on Mar 06, 2015
The freezer door will not open. it feels locked
There is no lock on that door and the only latch is a magnetic gasket around the door edge. It sound like one of your frozen packages make have shifted and is causing the door to stick by hitting the package. Just guessing on this one but maybe if you can bounce or jar the refrigerator somewhat the package may move enough to open the door.
3/6/2015 8:18:05 PM • GE Profile... • Answered on Mar 06, 2015
My GE bottom freezer is freezing up. Where is the defrost timer?
30 years in the business tought me that the defrost timer is no 1 for defrost problemes and defrost thermostat is no 2 before and the element is rarelly defective on your model its under a panel on the back of your appliance How To Install GE WR55X10942 Main Control Board
1/7/2015 5:20:56 AM • GE Profile... • Answered on Jan 07, 2015
I cannot find my defrost timer on my GE modelsPDS22SFSBLSS
electronic board behind panel on the back of the ref
1/7/2015 5:08:07 AM • GE Profile... • Answered on Jan 07, 2015
How do I remove the freezer drawer of a GE Profile refrigerator
PFS22SISASS GE REFRIGERATOR Manual Instructions are on pages 22-23
9/18/2014 2:32:47 PM • GE Profile... • Answered on Sep 18, 2014
Freezer is working fine but refrigerator is not ?
had the same problem here.. Just switch off your fridge for around 8-10hours it should work just when u switch it back on.. Hope it works for you!
6/11/2014 2:21:39 PM • GE Profile... • Answered on Jun 11, 2014
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
214 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
hotpoint refrigerator custom craft no
  • Refrigerators
