20 Most Recent
Sony XPlod CD Player w/MP3 Playback CDX-GT40W Questions & Answers
I have a sony explode
It sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire ( amplifier remote turn on) to turn your amp on. The power antenna remote turns off when leaving tuner mode.
My iphone asks for a
You enter a code on the source device, enter the code again on the head unit (using the remote control is the easiest way to do so), and the two devices connect.
How do i reset my clock on my sony xplod cdx
To set the clock:
Press and hold the select button until the setup display appears.
Press the select button repeatedly until "CLOCK-ADJ" appears
Press SEEK + (the hour indication flashes)
Rotate the control dial to set the hour and minute. (To move between hour and minute, press SEEK + or -)
After setting the minute, press the select button and the setup is complete.
To display the clock, press the DSPL/SCRL button.
I have a sony cdx-gt45ip
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
I recently installed my sony
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
NO SUB OUTPUT
The sub outputs are simply lowpass filtered preamp outputs for use with a subwoofer amplifier. They supply a lowpass filtered signal for a subamp or 'powered subwoofer" like a bazooka tube. Test your "basstube" for 12 volt input power and make sure the "sub" setting on the radio is turned up too.
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
