20 Most Recent Maytag Atlantis MAV6000 Top Load Washer Questions & Answers
Maytag atlantis washer(spinning problem)
Your problem sounds like a broken belt . Check and replace. Good Luck Friend.
1/30/2018 2:27:16 AM • Maytag Atlantis... • Answered on Jan 30, 2018
My Maytag Atlantis (MAV7600AWW) just
it sounds like there is something stuck in the water pump you will need to lay the water outlet on the floor into a shallow vessal to empty it then that the back off locate the water pump and see if you can rotate the cooling propeller if not take the motor housing apart to remove the debris that's preventing it from turning if the motor has not burnt out eric
1/1/2018 3:28:54 PM • Maytag Atlantis... • Answered on Jan 01, 2018
I have a Maytag Atlantis
Hi Greg. this is all i could find,go to this link and see if it helps you out. Maytag Atlantis washer Model MAVT754EWW how to clean the hose Screens that...
11/4/2017 2:27:36 AM • Maytag Atlantis... • Answered on Nov 04, 2017
Maytag spins but makes clunking noise and clothes are still wet
The model number would help, ya know?
10/3/2017 5:51:40 PM • Maytag Atlantis... • Answered on Oct 03, 2017
I have a maytag top
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
6/16/2017 8:11:13 PM • Maytag Atlantis... • Answered on Jun 16, 2017
Maytag Atlantis MAV6000 Top Load Washer Logo
1,252 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
remove maytag inner tub
  • Washing Machines
