20 Most Recent
LG Heat cool Window Air Conditioner Questions & Answers
AC Compressor
Does not sound right to me.My guess after doing what every he was doing he probably installed a start capacitor or repaired a burnt wrie, got the compressor running and charged for a lot of guess work. Just guessing.
Why did my ac quiet blowng heat
Check the controls, this unit most likely a reverse cycle air conditioner. It can be set to cooling or to heating. The conpressor is reversed to heat or running normally to cool.If it is not then the compressor is not working and it is just blowing room temperature air.
Why is the floor under koolking wet
If the drain is clogged or the ac is not slightly tilted towards the outside, the condensed water will leak inside instead of outside where it belongs.
Ice is forming on coil fins...
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
LG lw1810hr window unit heat not working
Check to see if there's power to the reversing valve, if there is, try tapping it slightly with something kind of soft. You should give the reversing valve solenoid a continuity check with an ohmmeter to see if it's open or shorted.
