20 Most Recent LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher Questions & Answers
13answers
LG Tromm - soap drawer is stuck and will not open
This is caused by the "Fabric Softer" removable tray inside the drawer getting stuck in the top of the drawer cabinet.
Solution:
1. Unplug machine
2. Remove four sheet metal screws and plastic plates from top of back of machine that hold the "lid" on (perhaps yours is different and only has two screws, but that's your world :) )
3. With the palm of either hand hit the both sides of the lid of the machine at about a 45 degree angle towards the back of the machine until the lid slides back about 4 inches
4. Gently remove lid (will lift off easily if you've freed it correctly)
5. On left you'll see a white box which is the cabinet for the drawer. Carefull pull the black wire from it's retainers
6. Lift up the three clips on the right side of the cabinet that hold it together
7. In the back of the cabinet, grab ahold of the plastic piece that doesn't have a hose attached (unless yours does, in which case figure it out yourself :) ) and gently pull up until you can see the cabinet coming apart in the back.
8. When you have enough clearence push a screwdriver through the opening you've created while lifting on the back of the cabinet apart, and PRESTO! The drawer will pop out.
This will happen everytime from now on if you do not remove the the "fabric softner" tray from the drawer. It is a design flaw that will happen to all models eventually. If you must have that little tray, then find a solution that works and post a follow up here (I imagine it will involve a bench grinder :) )
HAPPY WASHING AND BUY AMERICAN!!!
8/18/2021 9:03:54 PM • LG TROMM WM2688H... • Answered on Aug 18, 2021
4answers
Grease stains on clothes from LG washer (tromm 2688)
We run a small hotel and have been having this same problem with our LG Direct Drive WM2301HW... but the stains aren't grease at all... they're from sledge buildup in the washer. I found this out when I cleaned the lint trap behind the small door at the bottom left, on front of the machine. I ran my finger around the interior and found it lined with black, stinky muck. Due to the low position of the filter, this area never fully drains, so the muck collects and the bacteria grows. Of course, this means the pipes or hoses to the filter are probably also lined with this muck.... Poor design!!! Try running the washer empty (no clothes) with a couple cups of honest to goodness chlorine bleach. Then run it again to make sure all the stuff that came loose gets pumped out.
1/5/2020 6:05:04 PM • LG TROMM WM2688H... • Answered on Jan 05, 2020
2answers
IE ERROR HAVE DONE WHAT REPAIR GUIDE SAID WITH NO RESULTS
this is inlet valve error message..its should replaced..might need to check harness may be damage ,,,
11/24/2019 6:30:15 PM • LG TROMM WM2688H... • Answered on Nov 24, 2019
2answers
Not working start button only
first check the lid switch. its a magnetic switch which tells the machine that the door is closed for it to start its operations. if that switch is OK then maybe your push in button needs replacing.
10/23/2019 11:44:57 PM • LG TROMM WM2688H... • Answered on Oct 23, 2019
Still getting LE code after replacing Hall Effect Sensor
i would guess you are getting a "tE" error code. that is a bad thermistor. pretty common. and it starts out as an intermittent error. it really is an easy fix. great online videos. check out appliancepartspros.com for both video and parts or repairclinic.com for video and parts. or youtube.com
7/2/2019 3:37:56 PM • LG TROMM WM2688H... • Answered on Jul 02, 2019
My lg dle0442w wont dry clothes blows cold air
Sometimes it is the heater element in the dryer. Other times the main circuit breaker has tripped one leg. Some 220V-230V breakers have two trip switches that are tied together. One half of the breaker runs the motor and the other half operates the heater. A defective breaker can also cause the problem.
5/31/2019 2:44:39 PM • LG TROMM WM2688H... • Answered on May 31, 2019
4answers
How to select "SPIN ONLY" cycle?
I TOO HAVE BEEN WONDERING HOW TO SPIN ONLY, AND I HAVE THE ANSWER :),, TURN THE POWER BUTTON ON, PUSH THE SPIN SPEED BUTTON NEXT TO DESIRED LEVEL, THEN PRESS START, THERE YOU GO , IT WILL ONLY SPIN, NOT RINSE AND SPIN :), BY THE WAY , I GOT THIS INFO FROM THE ONLINE MANUAL :), SHOULD WORK....
10/8/2018 12:27:44 AM • LG TROMM WM2688H... • Answered on Oct 08, 2018
2answers
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
10/4/2018 11:05:02 AM • LG TROMM WM2688H... • Answered on Oct 04, 2018
3answers
My LG washing machine is flashing PE
Here you can find the solution for any kind of problems occurred in your LG Washing Machine. http://aktechnoservice.com/lg-washing-machine-service-center-in-hyderabad/ lg washing machine service center in hyderabad-jmdt4jy3zjzrdue5nmvphq4g-5-0.jpg
9/4/2018 11:58:21 AM • LG TROMM WM2688H... • Answered on Sep 04, 2018
LG Top Loader WF-T8108TP - NOT SPINNING
unplug the machine take the back off and look for a small pipe 5mm going upwards, take it off and blow gently into it you should hear a click and one when you let the air out if so then the place you took the pipe from is blocked clean out the pipe with a pipe cleaner or metal rod replace the 5mm pipe put the back on retry the machine eric
1/17/2018 8:10:12 PM • LG TROMM WM2688H... • Answered on Jan 17, 2018
The washer leaves grease stains
Have u tried a tub clean cycle
9/13/2017 4:32:53 AM • LG TROMM WM2688H... • Answered on Sep 13, 2017
We have an LG Tromm Steamwasher WM2487HWM . 4.0 cu
Replace the boot with new. While you have top and front off to replace boot, hose the drum down with a hose on stream. Remove filter clean out as you hose it down. Btw, there is no cleaning off the boot if it has mildew/mold on it.. it's slightly porous and no eliminating it
8/6/2017 4:59:58 AM • LG TROMM WM2688H... • Answered on Aug 06, 2017
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
5/5/2017 2:43:57 AM • LG TROMM WM2688H... • Answered on May 05, 2017
"Door Locked" Indicator Switch Faulty
Replace door lock. Pretty easy
4/6/2017 4:58:27 AM • LG TROMM WM2688H... • Answered on Apr 06, 2017
I got my lg tromm
Just pushing the button labeled 'beeper' doesn't work? Turn pose on, press beeper
3/10/2017 5:28:07 AM • LG TROMM WM2688H... • Answered on Mar 10, 2017
2answers
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly This causes: Your pump is clogged. Your pump is not connected. Make sure your pump is repaired, and try again.
7/2/2016 8:02:14 AM • LG TROMM WM2688H... • Answered on Jul 02, 2016
3answers
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
3/16/2016 3:10:24 PM • LG TROMM WM2688H... • Answered on Mar 16, 2016
803 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
lg tromm soap drawer stuck will not open
  • Washing Machines
