20 Most Recent
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Questions & Answers
Dishwasher smoking
nothing specific until you get a technician to properly diagnose the fault
Water leaking comming from the
That gasket is supposed to look like that. Use less soap and/or replace that gasket. It is very easy to do but pay attention to how the old on is placed. There is a small notch that has to be placed right.
Dishwasher will start on delay start but won't start with start button
Good Morning Friend,
I understand your Frigidaire dishwasher, model# FBD1050REC, will start on delay start but not just by pressing the start button. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Dishwasher latch
hi there,
check the door latch and door handle to make sure that there is nothing broken or bent. otherwise, you have to replace the door locking mechanism.
Why do my frigidaire ultra quiet ii does not dry?
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# FDB1050REC, is not drying your dishes. I also see you want to know which part needs to be replaced. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to not dry the dishes. Hope this is helpful.
-Best Regards-
WP
How do i remove front door cover?
I understand you are replacing the soap dispenser in your Frigidaire dishwasher, model# FDB1050REC, and want to know how to access the screws to remove front panel of the door. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals for this repair. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Fdbb4365fco
I understand that your Frigidaire dishwasher, model# FDBB4365FC0, will not drain. I also see that you do not have a manual. Try these troubleshooting tips below.
1)If your appliance is hooked up to a garbage disposal, make sure the disposal is empty.
2)Make sure the knockout plug has been removed from inside the garbage disposal.
3)Check to see if the drain hose is kinked.
4)Make sure the cycle is complete and not in pause.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. Hope this is helpful.
-Best Regards-
WP
FDB4315LFC2 runs then stops and flashes pf ?
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
