20 Most Recent Whirlpool GHW9400 Duet Washer Questions & Answers
Water will come in at beginning of cycle on a Hot/Cold wash but not in rinse cycle?
because the rinse uses cold water and u may have a cold water issue with the water inlet valve, the water inlet valve cold coil may have gone bad. test it with a meter and voltage 25691451-izj50bzy441rirqhwblyybfs-2-0.jpg 25691451-izj50bzy441rirqhwblyybfs-2-2.jpg 25691451-izj50bzy441rirqhwblyybfs-2-5.jpg 25691451-izj50bzy441rirqhwblyybfs-2-9.jpg 25691451-izj50bzy441rirqhwblyybfs-2-14.jpg
5/12/2015 4:34:38 AM • Whirlpool... • Answered on May 12, 2015
Error code F 6
4/20/2015 9:10:30 PM • Whirlpool... • Answered on Apr 20, 2015
How do I unlock whirlpool washer
Hold lock button in for 3+ seconds
3/3/2015 4:50:09 PM • Whirlpool... • Answered on Mar 03, 2015
How do I get the relay off the CCU in Whirlpool Duet Washer?
not made to repace ccu
12/17/2014 5:47:48 PM • Whirlpool... • Answered on Dec 17, 2014
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, or it reduces the cold water to a trickle, which sometimes causes the washer to throw an FH code. It does not h
Hi. Got some info about the FH error from Whirlool service manual.F/HNo water detected entering machine or Pressure switch trip not detected.If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.In my experience the CCU is the problem (control board).IF the machine has water! If not, check water valve, hose, water tap.Do it overfill? If thats the case, the pressure switch is gone, its hose has a leak.Hope this helps you
9/27/2014 10:29:01 PM • Whirlpool... • Answered on Sep 27, 2014
Know what is causing my washer to be off balance . I have made sure it is level already.?
If you leveled it for sure and legs are tight u probably are putting to much clothes in there so on spin causeing it to wable
9/26/2014 11:42:44 PM • Whirlpool... • Answered on Sep 26, 2014
0answers
0answers
0answers
Error code F06
Be the first to answer 7/4/2014 8:00:01 AM • Whirlpool... • Posted on Jul 04, 2014Be the first to answer
Beeping
the beeping usually is there to tell you something.
It is possible there is not hot water being supplied when you have hot or warm selected
Maybe the water is filling to slow
maybe the filter i clogged
maybe the barrel is out of alignment ( cased but imbalance from previous wash )
is it a top or front loader.
what lights flash when the beeping occurs?
7/1/2014 5:05:14 PM • Whirlpool... • Answered on Jul 01, 2014
0answers
0answers
Washing Machines Logo
167 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
duet Whirlpool
  • duet Whirlpool
Most Popular Question
uneven rotation basket bang noise
  • Washing Machines
