AEG Washing Machines • Uploaded on Sep 12, 2013
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
15 questions posted
181 Questions
148 Questions
95 Questions
55 Questions
58 Questions
